OT sump pump plumbing question
Jim in N. Va
Why would there be a 1/4 inch hole in the pipe leading from sump pump?
My daughter and SIL recently bought a townhouse and the home inspection report said the sump pump was not working/had to be replaced. (It's in a somewhat awkward spot that will be my SIL's workshop, so I'm not sure how hard the inspector looked at it.)
The sump pump (located in a standard pit) is directly plumbed into a 1.5 inch PVC pipe that runs straight up (8 feet or so) to the top of the basement wall and then turns and exits the building.
When I poured water into the pit, I found the pump ran but...and this is the curious (at least to me) part...someone had drilled or punched a 1/4 inch hole in the vertical run of the PVC pipe just above the pump, but still in the pit. So, when the pump ran, water squirted out of the hole in the PVC pipe and then continued to leak out after the pump stopped running (from the column of water in the pipe that's below the check valve). So, while most of the water in the pit was pumped out, some drained back and the pump had to run longer.
My set up at home is nearly the same and I don't have such a hole, so I replaced the PVC pipe at my daughters.
My question is, did the hole in the PVC pipe have a purpose (such as releasing pressure)? Should it have been there? And did I screw up by replacing the PVC pipe and not including the hole?
