Re: Bent wood lamination questions
TomD
Since the end result is going to be more stable than solid wood, it really doesn't mater. If you are making a heavily loaded structural member there is an advantage to quarter sawn.
There can be an advantage to altering the run out so that you in essence get a very minor plywood like effect. But where that can be a huge pain with a project like this is if you intend to cut the object with directional tools, like routers or blades. The problem with that is you can organize things so that you get tearout no mater what way you plane.
I had some projects like that early on and called up Michael fortune, and his response at the time, which may have changed in 30 years, but I doubt it, is to make the choice that makes it look the best to you. In other words, grain directions and all that are secondary. There is a saying in Archery that a bow full drawn is 7/8ths broken. Well a table sitting there is like 3% broken, so who cares.
As far as bending the material, you just have to play with it. Unless the bend is extreme, you can get very tight bends out of 1/8" Try to lay out a pleasing curve that is progressive, and not hard at any point.
The best thing for not getting splintering is as follows:
- Good wood that is straight grained reasonable species, but for cold bending, most things work up to a point. Straight grain all around is what you want, but particularly in the plane of plies (direction of the bend).
- Correct thickness, small changes in thickness make a huge difference. For instance double the thickness stiffness goes up by the cube of 2 or 8 fold.
- What looks nice, and works well is tapering the strips to suit the taper of the leg. That makes the leg stronger, reduces work, makes it easier to bend usually, keeps the grain less cross cut in look, and allows you to significantly straighten wood that is good enough to use in the first place. The latter meaning, you want no run-out over the length of the strip, but if it ran out just a little, you could correct one side to take the bending strain during prep of the strip, by tapering away the run-out.
