Need help with upholstered wooden benches!
blackCarol
I work in a house of worship and we have upholstered wooden benches. We had labeled the seats for a function using address labels which, in the past, come off without a problem. For some reason, this year they didn't peel off so the maintenance crew used goo off and a putty knife to scrape them off, ruining the high gloss finish. There are now large areas without any finish. I don't have the money to bring in professionals and need to fix it myself. We tried brushing minwax on a small area but it leaked into the upholstery. What would be the best method to fix this? I don't want to have to strip the lacquer from the rest of the wood if I can avoid it as the place seats close to 800 people and almost every seat is damaged. Any suggestions as really appreciated!
Re: Need help with upholstered wooden benches!
Keith Newton
Carol, Sorry to hear your dilemma. It is hard to believe that someone would keep using the goo stuff, if it was removing the finish as well.
In the future, I first would try using a hair blow-dryer to warm it up, as you push a dull putty knife against it. Most of these glues soften with heat. I have a friend who owned an advertising business that I think told me Bestine was what they used on these things.
I'm wondering if lacquer was actually the finish, although when it is old, it can be pretty easy to crumble. I think I would try to use a brush on lacquer like Deft. It dries slow enough to brush, but faster than the poly.
These kind or repairs are hard to advise from a distance without seeing the actual problem
blackCarol
Keith,
Thank you. I'm going to try that!
Thanks!
