This has to be one of the more patience trying undertakings I have ever experienced in the shop. I did put some thought into this. I wisely looked up the 5-cut method of squaring the fence and proceed accordingly. Using a drafting square I very roughly set up the fence the first time and screwed it down. So roughly, in fact, that I threw the square away.
I then proceeded to prove to myself that the Wood Whisperer's video on the subject of alignment may have been a bit lacking in detail. It would appear that the concept of unit error over the length of the rotating fence was elided in the video I reviewed. Or at least it wasn't obvious to me. I managed to yo yo at around 5 thousands error (plus/minus) with a couple of side quests engendered by accidentally adjusting the fence in the wrong direction, which is frankly not hard to do. With the video's admonition to "not go crazy with this; don't do it more than twice" ringing in my ears I went back into the house to look for a new source after six tries.
William Ng's description of the process was much more complete and with another four attempts (again with the dreaded 'which way does this correction go again' error) I had the thing dialed in to within .0005" of error. At this point my pride would like to suggest that I am currently an expert in this technique, having undertaken the process as many as 8 goes more than any of you, but I cannot seem to shake the suspicion that on that last try I was simply lucky. At this point I'll take it. I may, however, give up woodworking if that sled ever goes out of alignment.
You could have stopped with the .005 error as you are working with wood and humidity changes over the course of a week will change board dimensions by at least that much.
I had the same "fun" truing a 45 degree sled and a 15 degree segment sled that cuts 12 segments to produce a ring for turning. They are locked down and I don't ever want to do that again. As far as wood movement, I use my sleds to make cuts that are glued up immediately. I want the glue line as perfect as possible.
You may be right, but I am anal about aligning my equipment ~ As a retired Engineer that worked with precision automated equipment, I learned many years ago that any errors in a process can and will end up compounding. My sled was aligned by standing 3 foot parallel boards on end on a flat cast iron surface and tweaking my sled until I could not feel any misalignment at the top of the boards (rotated on the surface and rotating the boards). I know I can "feel" less than .001" misalignment, so my sled ended up at least accurate to less than .001" in 3 foot. If the board moves .005" later it will be off .005" not .010" or so. I also have my saw fence aligned and my joiner, drill press, mortice machine, Router table (perpendicular to surface) etc. so any fit problems will be in the wood movement only!
I can make enough mistakes on my own without introducing errors from misalignment of the equipment. It really doesn't take a lot of time to insure all my equipment is a close as I can align it, compared to my project time. I have an accurate straight edge from Lee Valley, several dial indicators from .001 to .0001", a certified square I use to check my working squares and digital calipers accurate to .0001.
Of course I could have stopped. But after listening to the cavalier "don't get crazy with this" statement and smug .0005 result, I was going to be damned before I let that sled win. Besides, this is part of a little project I have going to become more comfortable with working with large sheet goods. Reducing the number of variables is important.
I gave up and bought a track saw. Layout is still critical, but adequately supporting and guiding a big piece on the table saw takes more space and muscle than I have, especially to cut accurately. Jerry
I made up a straightedge using two factory edges of a sheet of plywood fastened together. One 8' length 5" wide fastened on top of a piece about 3" wider, 8' long. I run my worm-drive Skillsaw with the shoe up against the top piece as a fence. This cuts off the bottom edge so that in future use I can just line up the cut edge on the sheetgoods for a perfect edge cutoff. The poor mans track saw. I've been using it for at least 40 years with good results.
Yup. Just get the saw's blade parallel the long side of the base if you can and use a good quality blade. I've made two passes - one scoring cut on thin veneer plywood and a second through cut. I didn't notice any 'stepping' between the passes.
I built a sled, installed the front "fence" (but not the back fence) then sawed the keft in it. Using geometry principals and a large compass I then established a line perpendicular to the kerf. I aligned the back fence with this line and all is well.
BTW, lumber movement has little to so with the desirability of being able to cut a 90 degree (or some other angle) on the end of a board. What ever angle is cut on the end will remain essentially the same whether the boards changes width or not.
In making a drawer with traditional dovetails it is essential that the ends be square. It was for this reason that I built a sled in the first place.
If you cut an angle, say 45 degrees in the end of two green pieces of wood and mate them together and wait for the to dry, the joint opens up. The angle changes and they open at the heal of the cut. Can't tell you how many deck rails have been ruined by that phenomenon. Beautiful miters one day look like crap a week later.
I know we are not discussing deck rails, but use dry lumber.
Another case where all bets are off is juvenile wood. Mother Nature may have a plan for it, but she has not revealed it to you. Cut it anyway you want and wait and see what you get. (an argument in favor of boxing the heart.)
It has been so long since I made my sleds, that I don't think there were any internet videos out. My first ones were just for one side of the blade, but later I made them larger, having always found that my last one wasn't large enough for what I needed at that moment.
I made the sled of out some phenolic faced plywood I had left over so the size was dictated by what I had on hand. The sled is about 24" inches deep and about 30" wide. I removed the phenolic from one side of a couple of 4" strips and laminated them for a solid back rear fence. The front fence is a single thickness of the same plywood. The thing weights about 25 pounds and feels very solid.
It has been a great help in the file cabinet project I'm working on, but has already proven too small for one cut I was considering. Same as it ever was.
For anyone making a sled you don't need it to weigh 25 pounds to be serviceable. I would recommend making a sled the size of your saw table. Use 1/2" Baltic birch for the base and quarter grain (to minimize width changes in runners) hardwood for the runners. Such a sled will be easy to handle. Leave the runners sticking out the back about 3" to make positioning it on the table slots easier.
Back when I made my first sled, I was working on a 9" Rockwell Contractor saw. I still own that saw, which has a top 25" W x 22" D. That is about the size of the first sled that I made and discarded shortly after.
Bill, I think I recall that you have a Unisaw, which is bigger and better, but everybody doesn't choose their projects like you do, and I suspect there will be many woodworkers out there who bought their TSs to bust down full sheets of plywood for cabinet jobs, so my advice to them, is to not go too small, if you only want to make and store one.
Besides the 9", I have a 10" Unisaw, and a larger 12" PM, with larger sleds for all.
But let me drop back to the little contractor saw. Back then, I was building cabinets on the job site, in big colonial houses, and would order about 30 - 40 sheets of 3/4" plywood at a time. Besides using the TS to rip those sheets down the middle for base sides, then half again for uppers, I made a larger sled to use for cutting my base cabinet sides to length. Like you, I used Baltic Birch, but left it 5' long, and about 32" wide. When I was cutting a bunch of parts 34.5" long x 23.5" W, the long end sticking off to the left, would be about 61.5" long, which was only about 1.5" past the balance point 30" out to that side of the blade, so I could easily stop it from tipping off with one finger holding it down as it passed over the blade onto the out feed-table.
Because it is hard to see over the far end to start the cut, I would carpet tape a sub-fence of 1/4" mdf to give a reference on the front. Then all I needed was a little pencil mark on the edge of the sheet to hit the length, with no need for a square. But when the sled is laying on the table, while trying to get a half sheet of plywood loaded into position, I found it useful, as well as safer to have some front to back length, to keep it from tipping off toward me while loading a half sheet.
Since the saw would need to be running already, due to the switch being too far back under to reach, the loading sequence would be like this. Position the sled with the back edge of the sled over the saw top, while setting the half sheet over the backstop, keeping it up on it's edge. Then I would move my right hand under the sled for support while pulling it back toward me, while allowing the plywood to lay back as it comes back. You don't want the sheet to come down on top of the blade, so having some extra front to back length is desirable, because until you have done this enough to develop muscle memory, you run the risk of pulling it off the front of the saw and dropping to the floor, which would likely break the sled in half.
As for the front and back fences, I suggest using 2" thick material, about 2" taller than the height of the blade when it is all the way up. One never knows at the time of building these things what projects will come along later, needing maximum capacity. It would be sad to have a nice sled break in half due to trying to make things minimal.
So my advice is to go ahead and make a larger one. It will still do the job just as precise as a smaller one. A big one may weigh 20# maybe, as opposed to 5 for a little one, but once it is on the saw, who cares how much it weighs, so long as it slides easily.
I have old sleds which have had wide dado blades and big blades used all the way up and tilted cuts which chew large opening, but they usually have a 1/4" MDF sub-top on them to provide zero clearance for the blade on the bottom, keeping that face splinter free. I love big sleds, I have one 8' long, and another about that wide. Both are great for their intended purpose.
If the sled is easy to handle it will get used more often. Made from 1/2" plywood mine is easy to lift and store. It is so handy to install that I rarely use the miter any more, and never use it for a cut that needs to be accurate. Plus I feel safer using the sled for cross cuts. If indeed it is safer anything that encourages its use is good, and easy to handle encourages its use.
By clamping a piece of lumber with a stop on its end to the fence of the sled repetitive cuts of several feet can be done.
