to answer the chemistry question....
The finishes we use can be divided into two categories, curing and not curing.
Conventional lacquer and shellac are solutions of the finish molecules. When applied the solvent evaporates and that's it. Expose the dry finish to solvent and they redissolve.
Varnish, polyurethane, pre and post catalyzed lacquer cures after the solvent evaporates. The stuff in the can is a solution of polymer molecules. After the solvent evaporates these molecules cross-link to form a few gigantic molecules. An analogy might be as follows. The molecules in the uncured finish are very long like a plate of spaghetti. The curing (cross-linking) links the spaghetti strands together in one or more places so there are no longer individual spaghetti strands. Hence they can no longer be separated into individual strands by adding back a solvent.
We often call this process "drying" which confuses the situation. The solvent dries, the remaining stuff "cures" (cross-links) An important property of a cross-linked finish is that it is insoluble in everything. A strong solvent may soften the cured finish but nothing will redissolve it. Also, cross-linked films are tougher than non-cross linked films.
Consult the supplier of finish to see if a precat lacquer can be recoated many days after curing. The curing reaction goes on for some time so that recoating is not an issue when done within a day or so. The details of the formulation will determine if there is any problem recoating weeks after application of the first coat.
