On Turkey Day my old fridge failed. I bought a Samsung fridge that has the double doors at the top and two drawers below. The doors have the flap in between that means it does not have a divider in the refrigerator compartment. I like the fridge so far except for one thing. On the old fridge I had it leaned back a bit and if you just touched the door it would drift shut. On the new one you have to push the doors shut to get the flap to flip into the right position. There is sort of a mechanical click, but some resistance. What I want to know is would it help to lean the fridge back and if so how much would I have to lean it?
Don't think so because ours is the same way. In fact if you have the left door open , which is the door with the flap on it, if you do not open the right door before closing the left it sometimes will not fully close and it looses it cool. Takes a while to get used to.
I don't know. I think I read something somewhere that said these new units like to be level. Don't know why. We have an older side-by-side that's tilted back a little. Even then, the fridge door wants to swing totally open. It's annoying when you open the door to grab something that requires two hands and it swings into the wall before we can catch it.
We've used the type of fridge you bought in several beach homes we've rented. I always wondered weather the little strip goes back properly when only opening the left door. However, the last one was the exact configuration as yours. I really liked the upper drawer when my wife pointed out it was for refrigerated and not freezer items.
except for this. Its sort of hateful that you have to be so firm about shutting the door. It has an alarm on it if leave the door ajar for three minutes, but the alarm is rather soft and easy to miss, particularly if you walk out of the room.
The manual tells you how to make the door adjustments, be sure and do them in order.
No I think leaning it back is a bad idea unless you want water in the ice maker running down the inside of it!
Apparently they don't do the adjustments at the factory as the right door on mine is lower than the left. One day I'll get the bug and adjust it, maybe.
