ADVERTISE HERE - FREE TRIAL
1991 Grizzly 2HP DC
1991 Grizzly 2HP DC
1991 Grizzly 2HP DC
Dustmaker Mike
Howdy all I am in need of bottom bags for my DC. I have had the current disposable bag on it for well lets say way to long. I emptied it a few months ago for the first time in a long time. The other day I was doing some real woodworking and turned it on. When I went into my garage at the end of the day I noticed saw dust all over the place. I guess a disposable bag won't last forever. I am just not sure of the model number or what kind or size of bag or bags to get. I have a place I can dump my saw dust so they do not have to be one use and toss bags. The motor states it is a 2HP TY-320A and it was made in 1991. That is all the information I have on it. Thanks Mike
Re: 1991 Grizzly 2HP DC
ChuckInND
Mike, I use to own a Grizzly G1029 that was a 2 hp model, but that one had cloth bags both top and bottom. I'm guessing that yours is maybe a 1029Z. Currently I have a Delta setup that uses a plastic bag on the bottom, and the way I get around from buying plastic bags is to put a separator before it. It has worked out very well for me, very little dust ever makes it to the bag now.
Thanks but the palstic bag has holes in it now
Dustmaker Mike
I am not the original owner I bought it used that is why I don't know the numbers and it already had the plastic bag on it. I am just trying to see if I can get a real bag for it or where to get more good plastic bags. Thanks
ChuckInND
Mike I'd also like to add that if you don't know, a separator has another bennefit other then saving on expensive plastic bags. With a separator your capturing the dust before it enters the impeller. One day I was thickness planing some treated wood for a deck. The wood was fairly wet, and what I found out afterwards was that the wet shavings had wraped and stuck to the impeller.
Re: Thanks but the palstic bag has holes in it now
ChuckInND
Mike, I understand, thats why I tried to help you out with a model number. The separator comment was just an attempt to help you in future use, after you find the bags.
Dustmaker Mike
Thanks I will look into one.
call Grizzly
Jerry Gibbs
I know Mike found the bags, but I have received excellent customer service from Grizzly.
