A55 Smoothing Plane
hard drive hours
hard drive hours
hard drive hours
Chuck in Mtl.
I have this hard drive that has in excess of 41000 hours of use. Is this unusual to see drives lasting this long?
Re: hard drive hours
That's five years. I have drives that have been operational for twice as long. You should have a backup drive, though, in case this one heads south.
Alex Grigoriev
The reallocated sector count is still zero, which is quite remarkable.
Still, it makes sense to migrate it to an SSD.
Stuart Johnson
Is the SSD used as a backup or in place of the normal HD? I saw something about being able to boot up almost instantaneously from I think a SSD.
Sandisk extreme 480GB
Chuck in Mtl.
that drive is my backup drive and my main "drive" is an Sandisk Extreme SSD which I like a lot.
Bill Howatt
The SSD is best used as a boot drive and while a lot faster, it isn't instantaneous when booting from a power-off and of course, it depends on how many applications you have installed, processor speed, etc. My i7 desktop with Win 8.1 boots from power-off Windows running in about 17 seconds.
The price of SSDs has come down a lot but they are still more expensive than a mechanical drive and the very large capacities are not available - at least not at a price you would want to pay.
Bill
Re: Sandisk extreme 480GB
Bill Howatt
The time shown is "Power On Time" and if it means the time the PC has been powered up supplying power to the drive power connector, it may well be much less than the actual operating time for the drive (platters spinning, data being read/written) especially in a backup function.
Nontheless, hard drives are vastly improved over the older models and really are a technology marvel. The downside is that they are so reliable that too many people think they never fail and thus never backup.
Bill
Tony - Memphis
We have several thousand of then installed in terminals we use to sort packages (we use them as a host to handheld scanners). We spec'd them because they last longer than a mechanical drive (in theory). So far, so good! These terminals rarely re-boot, are powered 24/7, and our storage needs aren't very much, so they are perfect. I noticed HP has some hybrid drives that make the most of both. I almost got one as part of a promotion for laptops, but I was too slow to decide and missed the deal. The new laptop with 8.1 boots really fast anyway.
Tony
Bill Howatt
Glad to hear they are working well for you. Not too long after the introduction of cheaper SSDs and the beginning widespread adoption by consumers I read a couple of articles that said the reliability was not any better than the mechanical drives. I don't know how the comparison was done given that mechanical drives have much higher capacity which probability would say would result in more errors. I imagine this can probably be allocated to the teething troubles of mass production of new SSD components.
Bill
Walt
I think a big advantage of SSDs is no moving parts so no head crashes etc. in mobile use. There was one brand - OCZ - that had some real 'issues' (something like 50% failure rate after a short time in service) that resulted in I think a bankruptcy or near bankruptcy and acquisition of OCZ by Toshiba.
Chuck in Mtl.
i think as the SSD technology matures and "bugs" are worked out reliability will cease to be an issue.
