Problem identified, don't know how to fix
The picture shows a MS SNIP of my screen after I do a "Preview" before sending a message. I have no idea how "slow" got there and less idea of how to fix the problem.
Re: Problem identified, don't know how to fix
David Yoho
Bill, have you tried erasing the word and then post? Then go back and try a test again and see if "slow" is still there.
I have been unable to get rid of it.
Either "preview" or "Edit" puts it there for good.
Re: I have been unable to get rid of it.
David Yoho
Short of erasing it each time you preview before posting, I don't have a firm answer. However, since this is only happening when you use Chrome, perhaps a totally clean install of Chrome will fix it. It's almost like it's stuck in the internal parts of Chrome somewhere.
John McGaw
Don't know how to fix your problem but I used to have a similar problem. Mine turned out to be that RoboForm, the program I use to fill passwords and Windows form, had memorized way too much and was sticking things in from an old session so I was able to go in and edit RoboForm's data to fix it. It took me an embarrassingly long time to figure out what was going on though.
guess
Jerry Gibbs
wonder what would happen if you set up a new account, or, tried posting from a different computer?
Autofill
The fact that the box is yellow says that Chrome is autofilling from some previous entry. Go to Settings > Passwords and Forms > Manage Autofill Settings. There are all sorts of options in there as to how to delete saved settings, specific settings, specific words, etc.
Not Autofil
I looked in Chrome Autofil and only my address was listed. Never-the-less I disabled autofil, made another trip through "preview" and "slow" got added, just as before.
Re: Not Autofil
Chuck in Mtl.
Bill,
I just posted a picture and had no problem. I am using Firefox. Maybe if you try a different browser it will work. The file i uploaded was a .png file.
Try this
Bill, the fact that the field is yellow tells me that it is, in fact, Autofill that is populating that text box. If you dig deeper you'll see some advice on deleting specific entries. Of interest is this advice:
When you type in a form field, a menu may appear, containing past text that you've typed in the field. To delete a specific piece of saved text, select it in the menu using the arrows on your keyboard, then press Shift+Delete.
You can call up the list of memorized Autofill words by clicking in the text box. A list should appear, hopefully including the offending word.
What I can tell you is that I have never seen this problem and I suggest strongly that WoodCentral code is not the issue, here, especially since it doesn't happen with your other browsers. We have not done anything that would suddenly introduce an anomaly like this on one computer in the universe -- yours. I can't suggest reinstalling Chrome, nor looking for malware, because, nothing suggests that will fix it, but you might want to reset your cookie for whatever messageboard is causing you these problems. Just go to Set Preferences and make sure your name and email address are correct, then hit Save (or Update or whatever it says). That should give you a clean slate. Then I would close Chrome and reopen it. See if that works. If not, and you don't want to clear that box every time you post (or each time it autofills), then try another browser.
One other thing... I have said many times here (and no doubt in the FAQs) that our scripts (the messageboards) set a cookie for you on every messageboard, browser and computer or device you use to access the board. If you use Chrome all the time and then switch to another browser that you have never used, there will be no cookie set for you, and you will have to either introduce yourself through the Set Preferences link or else preview a message. As soon as you give the browser some input indicating that you are the Bill Tindall who is a registered member, it will immediately recognize you and afford you all the bells and whistles of membership.
Hope some of this helps.
none of these tricks worked
Bill, the fact that the field is yellow tells me that it is, in fact, Autofill that is populating that text box.........what adds the saved password, the WC software or Chrome?
When you type in a form field, a menu may appear, containing past text that you've typed in the field..........found it.
To delete a specific piece of saved text, select it in the menu using the arrows on your keyboard, then press Shift+Delete.....didn't delete it
You can call up the list of memorized Autofill words by clicking in the text box. A list should appear, hopefully including the offending word......... The offending word did appear
What I can tell you is that I have never seen this problem and I suggest strongly that WoodCentral code is not the issue, here, especially since it doesn't happen with your other browsers........It didn't happen with Explorer because I never "activate" Explorer to use WoodCentral so WC doesn't know me when I call up WD with Explorer.
Just go to Set Preferences and make sure your name and email address are correct, then hit Save (or Update or whatever it says)......did all of that and it didn't fix the problem
then try another browser. .....that didn't work either. Tried to register with Explorer and got a password error
. As soon as you give the browser some input indicating that you are the Bill Tindall who is a registered member, it will immediately recognize you and afford you all the bells and whistles of membership.....it didn't. It said it didn't recognize my password
Hope some of this helps. Nope!
Re: none of these tricks worked
Chuck in Mtl.
maybe try firefox rather than explorer. Its along shot but the password can be reset by ellis.
Invalid password
This error message comes up when you attempt to post with somebody else's name. You will need to Set Preferences to your registered Profile name and address.
