Oak finish advice sought
Larry Rupprecht
Just about to finish sanding on a red oak headboard. Very simple Mission style, 1-1/2 x 3" x 44" high posts, 3-1/4" wide horizontal rails supporting a set of eleven vertical stiles. Mortise and tenon construction throughout and no fasteners except pins on the back side of each joint through the tenons. The top rail is covered with a 1-1/4" wide x 5/8" thick cap. All edges and post tops are chamfered to break the sharp edges. The face grain is rift with a few very subtle ray flecks showing on some pieces.
The cap and the top rail are also showing a subtle tiger stripping and I'd like some advice on how to "pop" that tiger stripping so it is noticeable after finishing. Not looking for the dramatic highlights, just something more than the almost totally hidden look that red oak ray flecks and tiger stripping normally present once clear coats are applied.
My normal finishing sequence is to sand all flat surfaces to 220 and any cross-cut ends to 320 grit, apply Cabot's golden oak oil-based stain, dry 24 hrs minimum, seal with three or more wipe-on coats of Seal Coat shellac cut 50% with alcohol. Next sanding is 220 followed by multiple coats of water-based polyurethane with 320/400 rubbing between coats.
Thanks for any ideas. this headboard is the last of the Christmas gifts for this run....until I get further orders from the Boss, that is.
