Solar Pendulums
Solar Pendulums
Solar Pendulums
Tony - Memphis
I decided to combine two hobbies into one and build some solar pendulums using some nice figured walnut for the tops. I bought a "box o' shorts" from that wood place in AZ. Got some nice pieces. Great for small projects. If you look close, there is a solar cell in a wooden frame behind each box attached with cloth covered wire. The pendulum has a magnet in the bottom. There is a coil that I wound on a spool I turned under the top. The circuit is really pretty simple - a couple of capacitors, a couple of transistors, a few resistors, etc. The pendulum will self start,which is pretty cool. Took some experimenting and testing to get everything just right. The boxes are 4 1/2" sq. for reference. Two of these are Christmas gifts and one is mine. I am attempting to embed a video for the first time, so bear with me if all doesn't go well!
Re: Solar Pendulums
Re: Solar Pendulums
Lee Schierer in McKean, PA
Really neat project. I could see lots of applications for that type of device. You could mount an animal on the pendulum and it would look like it was moving.
Lee
Re: Solar Pendulums
Re: Solar Pendulums
Joe in a Cleveland suburb
What a neat idea Tony. Nicely done.
I wondered if the solar cell could be attached/inset into the back of the box. My wife has those silly little plastic things you put near windows that wiggle. You know, they are little elves or whatever kind of figure.
Fun looking project.
Re: Solar Pendulums
Re: Solar Pendulums
Rik, WI
Very cool. What sites do you recommend to learn more about the circuitry?
Re: Solar Pendulums
Re: Solar Pendulums *LINK*
John McGaw
I don't have any information beyond my own intuition but Google comes through with more information than you could possibly use. Search for 'electronic pendulum circuit'.
Circuits Galore
Re: Solar Pendulums
Re: Solar Pendulums
Tony - Memphis
I used a whole bunch of references, but the basic circuit design is the same.
Here are a couple:
http://www.accomplished.org/2010/06/02/solar-pendulum/
http://www.instructables.com/id/The-Magbot-pendulum/step4/Putting-it-all-together/
http://skolnik.hackhut.com/solar-pendulum-efficiency-circuit/
http://www.bowdenshobbycircuits.info/swinger.htm
This is where I got started:
http://nutsvolts.texterity.com/nutsvolts/201208/?folio=32#pg32
I purchased the magnet wire on ebay and made my own spool. Be sure and do your testing with the cicruit in the same proxmiity to the coil. I didn't and found that ti didn't work as well. I assume all the metal in the circuit affected the coil. Adding an additional capacitor (I started with a 2200) helped the self starting. My test setup was very very crude, but it worked great out in my shop (masking tape, string, etc.). Mine requires a fair amount of direct sun so work. With no metal near the coil and very light pendulum, it takes less sun to get them going. I think I have enough parts left to build one more. I may make an ugly one for the shop and mount it on a wall with the cell mounted in the window.
Came in from the shop yesterday and mine was sitting in the afternon sun and it was going like crazy! Due to our trees and such, that's when we get the most direct sun into the house this time of year.
Fun project!
Tony
