Removing Rust Inside Pulley Hub
don stephan
When I drove out the shaft, found out why I couldn't move the pulley sideways on the lathe spindle shaft (to align the upper and lower pulleys). There were some thickish areas of rust on the shaft and the inside of the pulley hub. With gentle use of an 8" mill bastard file and coarse steel wood I was able to remove the rust from the shaft, and most from the inside of the pulley hub. But there are still some dime sized areas of rust on the inside of the hub that the steel wool isn't affecting. What grit wet/dry paper could I use? The pulley is secured with a long key and pair of set screws, but I don't want to remove more metal than necessary. Thanks.
