Table saw noise
Lynn Reedy
I have a powermatic 10 inch table saw that is making
a strange noise. I believe that it is coming from the trunnion.
Does anyone recommend a dry lubricate for the trunnion?
Thanks,
Lynn Reedy
Soddy Daisy Tenn.
Table saw noise
Lynn Reedy
Thanks,
Lynn Reedy
Soddy Daisy Tenn.
Lube
I use "dry" graphite lube on my table saw (JET Cab) trunnions. Smooth and quiet. What noise?
Re: Table saw noise - More info? *LINK*
Bob Entwisle in NJ
Hi Lynn,
What sort of noise?
Is this a noise it makes when running?
A noise when off when raising/lowering or tilting the blade or?
I use Johnsons paste on the moving parts on my Unisaw. You need to clean off the old lube and accumulated gunk first. An old toothbrush and sometimes a spritz of WD40 helps for the cleaning.
Bob in NJ
Tablesaw lube thread
Re: Table saw noise
Common problem. Pack some Johnsons paste wax into the gears, as recommended by Delta service technician (in 1970 when they had such things).
