Ditto... and *LINK*
Grant in Iowa
Oneida is a class act. Great products, great customer service too.
I installed a (then) newly introduced 2 HP "Gorilla" in about 2005, and completed the ducting in about 2007. I am over the moon happy with it.
One thing to keep in mind when deciding how much to spend on a Dust collector (DC) is that it will run about as much as all of your dust producing tools collectively. This means you want a well made machine with a good motor. Mine came with a conservatively rated 2HP Baldor motor.
The ducting is expensive, but after I shopped around and toyed with doing my own using HVAC parts, I ended up writing a check to Oneida for their standard piping system. Since I can weld, I saved some money by making my own reducers from their straight piping. Their standard ducting is actually very heavy duty, you will need a metal cutting bandsaw or cut off saw to cut it. I used a 4" angle grinder with a cut off wheel.
My DC has a seven inch inlet, and my piping layout kept it at seven inches until it got to two main branches, where I reduced it to 6". I then ran 6" to every machine except a drop to my drill press, where I used a 4" gate and a 20' length of flex hose left over from my old system. This allows for quick shop cleanup, and an added line to use for odd situations.
I did design my own DC system, mostly since I am a control freak. I read up on dust collection at Bill Pentz web site on the subject, link below. As I said above I made my own reducers to go on the tool side of the blast gate to reduce it to a size the flex hose would fit over. I simply cut a piece of straight piping about 8" long, then using an angle grinder with a cutoff wheel, I made about a 5" cut beginning at one end, parallel to the pipe. I used a hose clamp to squeeze that end until it fit in the 6" hose. I then ground the galvanization off where I wanted to weld and tacked it back together.
As I assembled the system, I used silicone and an acid brush to seal up every joint.
I should say that an important step is to "live" with the new shop and tools for a year or so...at least several projects. During this time, use a long flex tube between machines to gather dust. I believe this is important because the machines will then "declare" where they want to be, so when you install permanent DC lines, they will not need to be changed. Short of this, think about how to organize the machines to be able to cut the longest boards you are likely to work with, or how you might be able to accommodate a sheet of plywood on your table saw without conflicting with other tools in the shop.
I also discovered that I could save money by having tools in groups, where they could share one drop from the ceiling. An example is my Band saw, Jointer, and Planer are all situated back to back, and share one drop, but with three blast gates and three permanently connected hoses. This works good, since the work table of each is at a different height, and they don't interfere. The more you can overlap in feed and out feeds of machines, the more efficient the space can be for a one person shop.
My machines all came with 4" DC connections, if they had one at all. These are inadequate in my opinion. I used locally sourced HVAC parts and some homemade parts to build 6" adapters. True, I didn't have the heart to cut 6" holes in every tool, but a 6" flex tube butted to a 4" hole will still move a bunch more air than a 4" flex line on the same fitting.
I should take some photos and do a write up on how I did my DC piping some time. I incorporated a lot of ideas from many years of thinking and reading about the subject before I finalized the design.
FWIW,
Grant in Iowa
Bill Pentz dust collection
