Candy paints are a bit tricky....
Tim Greif - West of Chicago
I've painted a number of motorcycles and one boat over the years. One of the bikes was candy apple red. The biggest problem with candy paints is the need for a uniform application thickness of the candy coats. Candy paints need a (typically) silver or gold metallic base layer. Primer color shouldn't matter, as long as you get good coverage with the base layer. The candy color is semi-transparent to allow the base layer's metallic properties to show through. Put it on too thin and you get insufficient coloration. Too thick and it looks too dark or diminishes the metallic base layer's effect. Not uniform in thickness and the whole thing looks different in different parts of the car. Done properly and it looks beautiful.
Seriously, I would not choose a candy paint job as my first automotive paint project. I got lucky because a motorcycle has a number of smaller parts (tank, fenders, side covers) where you can more easily control your application technique. Even the pros can have trouble with candy paints if they don't have much experience with them.
Good luck.
