Veritas - Innovation in Tools
need help solving a problem
PIC 1
This carving board is particularly functional. A cleat across the bottom (out of view) raises the tapered edge to be horizontal to the surface the board sits on. Liquids run to the bottom and not onto the table. Daughter wants one for Christmas.
PIC 2
A way to make it would be to turn a platter and then somehow remove the rim at an angle. Had I gone the simple route I would have simply hand planed the rim to shape, but I made the board end grain which is going to be a challenge to plane and not chip out edges.
Any ideas how to make the tapered rim?
Re: need help solving a problem
Belt sander?
mount it on the lathe crooked
Phil Smith
Tapered sled on drum sander.
Lars is right. It would be pretty easy to mount it "crooked" and turn the rim off and then turn the bottom to match, if you left enough thickness. Did you turn that yourself? If so, maybe we can give some advice on mounting it. (I can't remember if you are a turner.)
Or you could use a drum sander like a Performax. Send it through with one edge raised many many times, Then turn it over and run the bottom an equal number of times.
Did you do this on your lathe?
Keith Newton
I think if I had done it on a faceplate on the lathe, I would remount it back on the faceplate, with a wedge slipped between, then just work the bottom, leaving everything else alone. All it would take is maybe 1/4" ~ 3/8" of tilt to be effective.
Although this would leave a high rim, where the other has almost no rim.
If that is the goal, I would take it to my bandsaw, then saw away the all the rim from one side, up to leaving it all on the other. Then I would drill up from the bottom for a couple of dowel feet under the thin side, leaving a 3 point stance for the bottom. The bandsaw would need a holding fixture.
Or, if you are good with a circular saw, you could just draw a line around the outside, to cut just shy of for the tapper, then power-plane or hand to clean up.
William Duffield
You've already done the first step, which is to turn the platter, I suppose using a face plate.
Second step: Make the cleat and attach it to the bottom of the platter.
Three: Attach the cleat to the face plate.
Four: return the rim. It will be parallel to the bottom of the cleat and the face plate.
Router sled? *LINK*
Grant in Iowa
Bill,
I am envisioning clamping down the bowl somehow and then using the router sled/ trammel technique often used to flatten very large boards. You could then use a straight cutting bit to make your cut, being careful to "climb cut" where you think it might tear out or chip.
Something like the below link only in your case the part gets secured at an angle, perhaps supported by some wedges. The fixture might be useful later on for other projects, too.
Regards,
Grant in Iowa
router sled at Lumberjocks
