36"Yates bandsaw
36"Yates bandsaw
36"Yates bandsaw
Dan long
i pitched this saw awhile ago pretty rusted but solid most parts are ok so far I'm happy. I have one minor issue and that being a belt system with a 20" pully. Now the pully has a shaft that runs to the bottom wheel on the saw. On the shaft it runs through two bearnings which are spAced 9" apart. These bearning are enclosed in a housing of iron and they need to be replaced trouble is I don't see how to get the bearnings out of the housing help me if u can . Thank Dan
Re: 36"Yates bandsaw
Dick Coers
Could they be babbit? Or is the machine newer than that? I guess I'll need a picture to help much more. They do make pullers that go in the inside diameter and expand and hook on the inner race. Then you have to pull against a spacer or 3/4 drive socket to pull it out.
Dan long
Well not sure if they are babbit or not but I would think not. I'll have to check serial number and see year it was made. Like I said they are in a housing on the shaft and don't any wAy to get in them. I know there a way just don't see it. If pic would help I could try and post them but not sure how . I think they just need a good cleaning and fresh grease there is no wobble everything is tight just not turning very freely
Keith Newton
I take it that you have not taken the pulley off yet. If you pull it, you probably can then go to the front and just pull the lower wheel forward pulling the shaft through along with the wheel. At that point, you can see what type of bearings are in there. it could be a long bronze sleeve, which will need regular greasing, as well as babbitt, or maybe ball bearings which press in from each side.
If it is a sleeve type, it may just need lubricating. And if you let your shop get cold, the grease gets stiffer, making it harder to get started before it warms up. How big is the motor?
Our old 36" had babbits. If they're babbit bearings, there should be cast-iron caps bolted on, possibly with some shims between that and the mating part. There should also be oilers there, or at least oil troughs with wicks. Absent these things, I suspect they are bronze sleeves as Keith suggested, as bandsaws spin at relatively slow speeds so ball bearings aren't necessary. These also need lubrication.
Ellis Walentine, Host
Dan long
Thanks for all the input I'm sure they Arnt babbit now they have Greece fittings and metal rings on all four sides there r two slots on each ring 1/4" sq I think if I hit them they will come off looks threaded I hope. Also on the shaft there appears to be a breaking system like shoes its huge and pretty impressive. Also the motor was mounted in the back on two 2 1/4" round solid steel I tried for ever with heat and lubes pounding on them couldn't get them out from the casting of the saw frame I was afraid to hit it two hard afraid to brake something. So I cut them off flush and ideas how I can get these out safely. Sorry for so much junk . Thanks again Dan Oh Wait one more thing to add is the rusty table 3x3 ft anyone know where here in lower mich that can grind a rave that big . That's it for now thanks
Dan long
Hi Keith I can get the shaft out but I have to pound it pretty hard u think I will be able to pound it back in without damage. Also looking for a 7.5 hp 3 ph around 1000 tons if u think that ok I will be trying to get the saw to run at about 1400 think that is about right. Thanks for your helpDan
Keith Newton
Hey Dan, Im not following what you are saying about the older motor mount, but it sounds like you have it out of the way, so I wouldn't bother with that anymore. You can mount your motor on the floor behind it.
As for getting the main shaft out, make sure there are no dings on the shaft under or outside the pulley location, and make sure that you get any rust buildup off before pulling the shaft. If you have calipers, check the front to see if it is a bit smaller. The wheel may need to come off, and pull the shaft out the back. If the shaft or bushing are totally crapped out, don't panic, I think you will be able to find them at a good bearing supply, and a machine shop can turn down to a fresh clean surface, or just start over.
Otherwise, I'm suspecting that this saw may have set out in the weather for a while, letting water in to rust the shaft, or worse, someone ran it long after it needed lubrication. I think I would shoot some grease in there, and spin it by hand for a little while to see if it loosens up. My old Defiance has a spiral groove milled into the bushing which moves the grease along down the shaft from where it goes in, which is probably a standard practice.
My old saw had a 5hp motor on it when I bought it. I probably used it 15 years before I put a 7.5hp on it. The 5hp wouldn't get it started without my help when the shop was cold, and grease was stiff, so I was pleased to get that behind me. After going through the change, I got to checking around, and found that some other makers like Tannewitz doesn't even offer less than a 10hp on their 36", so I didn't go as much as I might should have. However, their saw will take 20" under the top blade guide, and mine only goes up 16", both of which equals about 2" of height per hp when running at the maximum.
My motor pulley is about 5.5", driving a 16", which puts the blade speed at about 60 mph, or 5588 fpm. This puts it in the high speed range, which would be great, if you were standing there trying to crank out hundreds of curved parts day in and day out, if that is what you are after. But if you are mainly planning to use yours for re-sawing, you probably would be better off with a slower speed and more torque. With your 20" pulley, you will already be there, unless you use a larger motor pulley. I don't use mine much for re-sawing, since I have a Woodmizer LT15.
As for your looking for a shop to mill the top, I would not be worrying too much about that. I've gotten some pretty badly rusted tops before on equipment that I've restored. I start with a old worn belt on my sander, then follow it with my random orbit sander grits down to ~220, then oil and wax them with Johnson's Paste was. By the time you have done that, that old rust pitting will just make it hold the wax longer. Seeing a shiny metal won't make it cut any better.
You can find used 3ph motors pretty cheap on ebay, if you have that in your shop.
Hope I've answered all your questions.
