Have a question? Ask Woody!
Short cord whips on portable power tools
Tom Dunlap
A while ago someone suggested removing long cords from portable power tools and replacing the whip with a stubby that is few inches long.
There were a couple of compelling reasons.
-Since most of the time an extension cord is needed anyway, just eliminate the whip
-The strain reducer, if there is one on the portable tool will take less cycling leading to less cord breakage leading to less shortening or replacing of whips
-No more cord coils to wrap up and store. Later, we all find that the Interdimensional Creatures have reached in and uncoiled at least one tool leading to a bird's next of cords.
I'm in the midst of moving so I'm looking at a couple of tools with cracked insulation at the stress reliever/tool end as well as the plug end. It seems like a good time to make the decision to shorten or replace.
Has anyone shortened the whips? If so, how long do you leave it?
If I'm going to buy wire I want to have cords, even shorties, that stay flexible in Minnesota winters. How do I find out which cords stay flexible?
Re: Short cord whips on portable power tools
No way!
Keith Newton
However, I make my living in the shop, and the tools that get used most are usually already plugged in, sitting on a shelf under the bench, so all I have to do is pick it up and use it.
One bad side effect that I see for shortening, is that the plug would be hanging on stuff as you try to move the tool around in use. Even gravity would always be trying to unplug it, unless you tied them together.
Whenever I do wind up the long cords, I fold them in the middle, which prevents the twisting, that is an inherent problem when you do just a single straight wind. When you just coil a line from one end to the other, each coil adds one twist when you spread the cord out to use. But when you bring the end of the plug up to where the cord exits the handle, then coil or wrap it around the tool, you are adding one right hand and one left hand coil simultaneously, so they cancel each other out, and only take half the time to coil.
Extreme weather drop cords
Re: No way!
Tom Dunlap
I'm no stranger to coiling! In my 40 years of climbing trees I've coiled a few miles of rope. From the first day my taskmaster taught me to coil. He would uncoil it and toss it back to me if there were twists.
A number of years ago we started using nylon rope bags or buckets to flake the ropes. My large rigging ropes get flaked into discarded plastic suitcases.
After my new shop is set for work I'll look at the tools. One idea would be to mount the male plug end solidly to the tool. That would be easiest for a circle saw, the nooks and crannies are there. Drill motor might be harder.
Re: Just the opposite!
I have changed the cords on some of my "favorite" tools with long (8') cords. As has been posted a short cord positions the plug and socket in an area that is almost guaranteed to catch on the edge of the workpiece.
Almost all Pro grade tools come with rubber coated (not plastic) 8' cords while the cheap homeowner grade tools come with a somewhat rigid short plastic coated cord. A few years ago I purchased an older - made in USA B&D 8" professional circular saw with a cut cord for $5. I tested the saw then ordered the original 8" replacement cord for about $20. There is no comparison between the Flexible rubber cords and the plastic ones.
I do save some power cords from worn out tools if they are good cords. The rubber coated ones will outlast a couple of tools!
Re: Just...size matters
Tom Dunlap
The tools with cracked cords Are well used Milwaukee's. Many years of use
Maybe longer would be easier. Now I have to reconsider :)
Wow that's cool
as a Photographer I have coiled thousands of cords especially extension cords. I learned a long time ago that coiling it around your arm was the worst thing to do. It twists the cord and eventually breaks a strand inside somewhere making it useless.
I always coiled the cords similar to what he shows in the video except without that second twist. If you twist the cord in your hand so it follows the way the cord wants to twist it will coil nicely and never damage the inside cords. I have extension cords that are 20 years old and used extensively that still work and coil great.
I will have to try his method and see if it works any better.
Jason Roehl in Lafayette, IN
Re: Wow that's cool
I've been coiling my extension cords this way for maybe a year or so now, after years of coiling them by hanging them from my hand, but always twisting the cord in the same direction. I won't say I've perfected the technique yet, but I probably spend a little more time coiling the cord, and a lot less time untangling it when I need to use it. I suspect that the audio cables in the video are pretty easy to do, because they probably have a very soft, flexible rubber jacket, and are a much smaller gauge than my extension cords (generally 12 AWG at least). The real bear to coil is my 100' 10 AWG cord...that one's a bicep workout.
Jason
Kneale Brownson
Cord flexibility
Kneale Brownson
I use SJ cable to make up extension cords or to replace tool cords.
Re: Cord flexibility *LINK*
Tom Dunlap
Thanks for the lead, Kneale.
I found this:
Please note that SJ has been superseded by SJOOW. Unlike SJ Cord, SJOOW features oil resistant insulation and an oil resistant outer jacket. Any SJ parts entered for RFQs will be quoted as SJOOW.
At this website:
SJ cable
