SuperMax 19-38 abrasive
John Foster
Hello
We have a Super Max 19-38 drum sander which was purchased last spring. We are quite happy with it. What I was wondering about was this. We so far have been using 3" rolls of bulk abrasive that we purchased from the machine's vendor. Where I work we have an account with a supplier that sells bulk rolls of cloth backed aluminum oxide abrasive in 3 1/2" and 2" widths, which I could get at wholesale price. As long as I correctly figure out the correct length and end tapers, is there any reason I could not use other widths on this machine? If so, which would you think I should try , the 3 1/2" or 2" .
Thanks
John
Re: SuperMax 19-38 abrasive
Dick Coers
Nope, any cloth backed will work as long as it's not so heavy weight that you have trouble getting it into the clamps. Experiment with the angles and length with some paper before cutting the abrasive. If you get the same width, an old strip makes a good template. I've read about a lot of guys going to Abranet on these, but I haven't tried it yet.
Ken Krawford
I have a Performax 16/32 and decided to try out Abranet. For this sander, the stock paper is 3" wide. The Abranet is 2 3/4" wide. I didn't consider that the taper would end up in the wrong position and ended up having to leave a 1/4" gap between the wraps.
I never did get the Abranet to work - it always shifted. I did use the regular instead of the heavy duty version of Abranet and they may have been my problem.
In summary, before you buy a bunch of non-standard sized paper take plain old paper the width you are considering and test it first to see where your taper ends up.
Dick Coers
Just curious Ken, did you use the standard angle on the Abranet? My thinking is that you can change the angle, and change the wrap. I'm thinking there would be a limit to what could be done, but I've never played with it. I bought a ton of paper on a deal when I bought my 16-32, and haven't purchased any in years.
I would think you could do this. I would take a strip of the sand paper and using a small clip, Attach it to the drum and wrap it in an experiment to get the angle right. you would probably have the guess at the first end, leave some extra length to fiddle with the angle and then cut it. Might be easier to start with a plain piece of paper, like a strip of brown paper if you have some and are willing to cut a strip.
I bought some odd ball stuff and it had the wrong backing on it. It was easy enough to rip it to the correct width, but it stretched in use and became loose and floppy and quickly shredded itself.
Its a dim recollection, but the paper backing is either K or J weight and I think it has been treated to make it stiff and eliminate the stretch. Somebody like Klingspor could advise you.
You could ask the supplier for a sample to try.
Ken Krawford
Dick, I did use the same angle as the 3" paper. I never considered changing it. I may have to revisit that and see if it would work.
John Foster
Thanks for the responses. I will probably give it a try on one roll. The potential savings is about 50%, too much to ignore.
John
An additional thought.....
This is purely speculation, but as the strip gets wider its angle across the drum gets more steep. I wondering if there is a point where it becomes problematic? Would the edges tend to snag?
Lars Parrington
Not all sandpaper widths will work because of the rotational orientation of the clamps that hold the ends of the paper. I made a crude CAD model, and it looks 2", 2.5" and 3.5" will all work fine. But, 4" and 4.5" for example would not work.
Also, it should be easy to calculate the correct taper angle for a given width. It is:
arctan( paper_width / drum_circumference )
2" --> 7.25 degrees
3" --> 10.8
3.5" --> 12.5
Lars Parrington
According to my CAD model, 2.75" paper, wrapped tightly, wont work. When you get it all wrapped around the drum, you'll find that the clamp is not in the correct position.
If you can cut/rip the paper down to 2.5", it should be close enough. Actually somewhere between 2.55" and 2.60" is ideal.
Lars Parrington
Oops, those numbers were for a 19/38. Unfortunately the outcome is the same for your 16/32 -- 2.75" wont work. Ideal width is somewhere between 2.50" and 2.55".
Lars Parrington
Thinking about this a little more, that formula should be arcsin, not arctan. But really the formula is not needed at all if you just realize that the length of the tapered needs to be equal to the circumference of the drum.
