Semi-OT Wiring Lamps ? *LINK*
mdclor
This is only a semi-OT because I made the lamps. When wiring them, does the wide prong of the plug attach to the black or white wires or does it even matter?
Arts & Crafts Lamp
mdclor
Arts & Crafts Lamp
Long = neutral, short = hot for me.
Re: Semi-OT Wiring Lamps ?
Lee Schierer in McKean, PA
Small blade is hot and the center contact for the lamp is hot.
Lee
mdclor
I guess I need to clarify. The plugs only have 2 prongs, they are equal in length and 1 is wider than the other one.
wide neutral, narrow hot
Rum
Its one part of the strategy towards avoiding loosing the "you are the shortest path" game.
john Veerkamp
Also, on the lamp socket, the Brass screw is for hot and the "white" metal screw is for the white or neutral.
Lets not forget the switch
Keith Newton
If only one leg gets interrupted by the switch, make sure it is the black, or hot. If the bulb gets burned out, and you or someone else tries to change it, not knowing that the switch is still on, can more easily get shocked on the threaded part, while changing out the bulb, if you are standing on a grounded surface.
My face is red
Randy Johnson
I have wired around three dozen houses by myself, helped on several more, and solo wired or rewired several commercial buildings.
I could not have answered the question off the top of my head. Unless it is really old, every male plug I have ever run across is color coded gold and silver. I was aware that there was a difference in the size of the prongs but I have just never paid attention to which was which.
wide tip is ground , white wire
del schisler
white ground world around
what do you call green, or bare?
Keith Newton
I think the white is Neutral, and green or bare is ground.
mdclor
I must not be asking my question correctly or I haven't understood the answer. In my youth all 2 prong plugs had both prongs the same width and they could be plugged into an outlet either way. Sometime in the intervening years, plugs started having one prong wider than the other so they can only be plugged in one way. I thought that it didn't matter because alternating current flows in both directions, but apparently I must have been wrong. Should the wide prong go into the hot (black) side of the outlet or should it go into the neutral (white) side of the outlet or does it really even matter?
Re: what do you call green, or bare?
Rum
You are correct, although electricians confuse the issue for the rest of us and call (white) neutral the grounded wire and the ground (green) the grounding wire. Which while entirely true and technically more accurate is certainly confusing for the layman. The difference is that "neutral" is the current carrying wire that is also connected to the earth whereas the green ground wire is an emergency return wire that should only be connected to the earth (grounded and grounding are bonded close to the earthing point but trying not to confuse the issue to much).
Understanding why there is a differentiation is interesting. After all isn't electricity a circuit so shouldn't both wires be "hot"? Why do we ground anyway? Doesn't that just make the system more dangerous because otherwise there would be no return path through ground and you could safely touch either wire (no circuit no shock)?
This doc does a pretty good job of describing the basic ideas and is interesting to read as a starting point:
http://amasci.com/amateur/whygnd.html
Scarily a large number of electricians have no idea on the why but have only rote memorized the what which can make things a bit interesting when you start running into weird exception cases (portable generators, transformers are some common points where things might have some variance from the norm).
You are correct that plugs used to go in a socket either way, but in keeping with safety and the advent of double insulated tools, they came up with the polarized plug to insure that exterior metal parts would have less chance of being live. Code officials thought it was a good idea so now I believe it has become part of the electrical code to insure uniformity across the country.
Unfortunately there are those out there that don't know the difference and wire things incorrectly that cause safety hazards.
Lee
john Veerkamp
wide plug goes to neutral/white wire
mdclor
Hallelujah!!! That is the answer I was looking for. Thank you.
Jerry Roberts
Sometimes it just takes awhile.Yuk,yuk
Think about it like this. The hot wire is the most dangerous so it gets connected to the narrow prong on the plug and this makes the narrow slot for it the smallest and most difficult to stick a foreign object into.
The white is less dangerous and thus goes to the wider prong and slot.
Modern devices are "color coded". "Silver" is considered a white metal. The screws are not actually silver, but they are sliver colored, thus the white wire goes to the silver screw.
Green is used for ground and ground wires are either green or bare. I guess the fact that both green and ground start with "gr" is enough to code them together.
Black is left and the black or hot wire goes on the brass (colored) screw.
Also, you can look closely at a lamp cord and one wire is smooth and the other one has a rib or ribs on it. I have forgotten which one is the hot.
The ground is different from the neutral in that the neutral return the current to the system, but the ground returns it to the earth. (I have studied this for years and still don'e exactly "get it".)
The ground is important with devices that have metal cabinets or handles. Electricity with take the path of least resistance and if you touch a device that has current on the shell and both you and it are grounded, you are a much higher resistance that a good solid ground and the current will go the other way and probably not harm you. I have personal experience with this.
The reason the hot goes to the little tongue down in the bottom of the lamp socket is that if it is hot and you start to unscrew the bulb, the contact is broken before the metal threads are exposed. If you put the hot on the threads, they would be hot until you completely unscrewed the bulb and much more dangerous.
Neutral v. Ground
Jason Roehl in Lafayette, IN
As you clearly know, the ground wire ("earth" in other countries) is a backup for safety purposes. Like you said, it's often connected to the metal enclosure of equipment so that if that equipment does inadvertently come into contact with a hot wire, the current will go through the ground wire instead of something else, usually people. Normally, however it carries no significant current (it will often carry some small current, preventing a static buildup when conditions are favorable for static charges to occur, but that's mostly a nuisance relief in a household context).
The neutral completes the circuit in a 120V circuit, so it is carrying whatever current the load has going through it. Once that current hits the main panel, however, then it goes through the ground bond--and to the earth, and that's how it completes the circuit with the power plant. There is often a ground wire on power poles, but that's not designed to carry the full "return" current--that's mainly to help protect against lightning strikes.
Jason
Tony-Memphis
I always have to look it up. Here is a good source:
http://www.familyhandyman.com/electrical/wiring/how-to-wire-a-light-socket/view-all#step1
There is some confusion regarding the Neutral and Ground circuits. First the Neutral is at or near earth ground potential. Actually the "Ground" rod or other (water pipe) is hooked up in every home to do one thing - that is to prevent the Neutral of the power company from "floating" or having a different potential from earth ground. If there were not many "ground rods" or other connections to earth along the many miles of power lines the Neutral would pick up voltages from inductance and or minor "leaks" in buildings. This could cause people to be shocked if they touched a "grounded" appliance while the person was grounded. Large factories with long length of wiring often have to install secondary "Earth grounds" tied to the ground wire along the lines to prevent an induced or leaked voltage from building up along the circuit.
When I wired homes in the Northern Indiana Power Company (NIPSCO) area many years ago they required that the Entrance box have a "bonding screw" installed that electrically connected the Neutral and Ground in the box. Other companies required that they remain isolated.
Our local utility does require Isolation.
Originally tools and appliances cases and metal parts were all connected to the "Ground" wire (Green or bare copper). The reason for this is that if a short occurs in the tool or appliance the ground wire will carry the voltage (instead of a person) and cause a fuse or breaker to open the circuit.
It makes no difference if the circuit is AC or DC, the ground is a safety feature to prevent shocks to personnel.
As has been stated the Wide blade (white screw) of all 2 or 3 bladed plugs must have the white wire connected. In the case of a 3 bladed plug the white is connected to the same white screw and the green or bare copper to the rounded blade (green screw). The "hot" or black wire must be connected to the narrow blade (Gold screw). Reason for this is that the common table lamp socket will have the "hot" wire connected to the center terminal in the socket. As you unscrew a bulb, the outside of the bulb is actually connected to the neutral (ground potential) so you will not be shocked if you touch the outside metal portion of the bulb socket while replacing the bulb.
Re: Semi-OT Wiring Lamps ? *LINK*
walta
Please be sure you use an underwriter's knot under that socket.
Walta
video
Thank you, I did.
