My lumber storage is in an outside tarp shed. I didn't used to mill to near size and sticker inside for projects, and I thought it was time I started. I've heard everything from waiting a day to several weeks. I have a few boards for upcoming boxes milled to within 1/16" stickered with just a full paint can for weight. I thought I'd let them go for few days then mill to finished size.
Anyone have practices that work for them? Anyone not bother with this at all?
Depending on your location, storage outside will only get your stock to a certain point on the dryness scale. In my area it will be "EMC" at 15% which is fine for outside use, but not for indoor furniture. When I store outside, I allow for 9 months per inch over three seasons; usually Summer, Fall, and Winter because MC will be lowest in winter.
I then move the stock into the shop, and restack, sticker, and weight it for several weeks at least or until my meter readings match the wood in the house structure. I do all of this rough; no preliminary planing etc. because rough-sawn presents a better drying surface than a partially "machine glazed" surface. Walnut dries faster than cherry or maple, so how much time the stock takes to get to EMC for my house (or your) is kind of a sliding scale deal.
Species, kiln dried or air dried (how long air dried), thickness from the shed, location, etc.... Around here, if it's air dried under a tarp, it's probably got powder post beetles too.
It will depend on original moisture content, target moisture content, species, thickness, grain orientation, length if it is short cuts, relative humidity and temperature of where it will be drying, air velocity in area where it will be drying. If these variables are known it may be possible to predict time. Or, weigh a piece and leave it to acclimate as long as it is loosing weight.
A modern kiln can dry 4/4 poplar in 4 days by the optimum control of temperature and air flow. For oak it is 30 days.
when I get lumber from Frank Miller, it has been kiln dried and then stored in unconditioned warehouse. If the delivery truck is flatbed I'll sticker and stack for 2 weeks before touching, if box truck (so wasn't exposed to moving air on the trip) I'll sticker and stack for one week. Then I joint one face flat and plane till both sides flat and smooth; then sticker and stack for another week. I don't take the first planning down so close to final needed thickness.
After that week to respond to flattening and straightening, I'll start with the jointer again. Most boards will only need one or two light passes for that side to flat and straight again, and I consider the wood ready to work, so I'll plane the other side parallel and take down to needed thickness. If more than two light passes over the jointer were needed, I'll plane the other face parallel and sticker and stack for a second week to respond. If after that second response week more than two light passes are needed on the jointer I'll scrap the board as too unstable.
I don't know how my practice compares with your wood, as mine has been kiln dried and stored well.
Forgot to mention the use of weights on air-drying stack(s).
Just as different species dry at different rates, they also differ in how they respond to the stress of drying. Walnut, for instance not only dries relatively fast, but it's also quite stable during the process. Cherry, OTOH, will "dance" (twist, cup, and bow) unless it's properly weighted. I use 4" solid concrete blocks spaced 6" apart for cherry stacks. This is especially important for the initial drying stage. Yes, it does make more work of shuffling the stacked boards (also important, especially at the beginning) but the straightness of the boards is greatly improved which increases the final yield of quality lumber.
Almost all of my projects are make using wood I have stored upstairs in my shop (Central heated and air conditioned year around). When I utilize that material, almost all of it has been in storage for at least 2 years. Therefore I don't need to acclimate any of this material. When I do seldom purchase kiln dried lumber it is from a vendor that stores it in an unheated building. Normally I sticker and stack this for at least a month, plane to about 1/8" to 1/4" oversize and repeat the stacking and sticking again for a couple of weeks. As Bill has stated a lot depends on the species ~ Walnut is very stable so don't do much with it, while Red Elm is the opposite.
Normally I try to stock the material I plan to use for future projects in my upstairs storage and use existing stable stock. I have a few thousand bf mixed of most furniture woods in my storage.
Much of my stock was purchased at Amish or Old order estate sales - air dried. When I acquired that lumber I stacked it with stickers and removed the stickers when I needed more storage area ~ sometimes a year or two later. My storage area is approximately 30' X 10' with a 8' ceiling (knee walls) and is pretty full at the moment.
First, describe your tarp shed. If it comes down on all sides, you might as well bury your lumber underground, because it will become wetter than air-dried for your area, wherever that is.
A full paint can is probably no more than 10#, which isn't enough weight for much more than veneer.
Bringing wood into a non heated or air-conditioned shop doesn't do anything. If you want to get it down where it should be, your shop air needs to be 25º warmer than the early morning temp, and for how long may depend on species, thickness, and starting MC.
