Oak table
Oak table
Odile
Oak table
Odile
We salvaged wood (oak) from France from my grand-father's drawing table . He was an ingeneer/inventor. So it is a 100 years old. We had the boads made into a dining room table. Unfortunately the boards are warping /curling from the outside edges inward. How can we stop this process?
We have put straps on it to straighten it, but it is not very conducive to using the table for what it is meant.
Can someone tell us what we could do?
Thank you
Odile in Virginia
Re: Oak table
Re: Oak table
Dick Coers
I'll try to keep this simple. Without pictures, I am assuming that you glued and screwed boards under the table top. With the furnace running now, wood is shrinking in the width. The boards under the top are not letting them shrink evenly, that makes it warp. Cracking can't be far behind if that is the construction method used.
Re: Oak table
agree.  act quickly
Principle: Wood expands and contracts with changes in humidity. Construction must be such as to allow these changes to occur.
The cause of your problem is straightforward. The boards are drying on one side faster than the other. And there may be some sort of constraint in drying somewhere. Go to where ever you go on this site to register and then post some pictures of the exact situation. Then we can give you some specific advice.
I fear that whoever made the table didn't know what they were doing. In any case get the table to where it will not further dry- porch, garage, etc. and wait further instructions. Or get it to a competent furniture maker- soon. You are on the edge of irreversible damage, or past it.
Re: Oak table
Re: Oak table
David Yoho
Given the fact that the wood is as old as it is and apparently didn't have this problem before the wood was repurposed for the new table, there are a couple of reasons why it's doing what it is doing. As others have already stated, the wood is probably moving due to temperature/moisture change and/or construction methods that don't allow for movement. Another possible culprit could be how the new table was finished. Coating the bottom and top of the table top equally is important and maybe it wasn't.
Like others also said, some pictures of the underside and top would help us give better solutions. Don't know where you are in VA but my shop is in Mechanicsville (Richmond area). If you're close enough maybe I can help.
Re: Oak table
More table data
The owner called me and I got more detail. The table boards run the short 4' width of the table with a 4" overhang which is curling up. The main part of the table is securely fastened to the frame and stays flat. The table is in an unheated room which is dry in the summer and damp in the winter. The bottom is unfinished, the top is varnished.
It seems that the problem is that the bottom surface is picking up moisture faster than the finished top. I suggested he dry it back out and varnish the bottom with whatever is coating the top.
Re: Oak table
Me too
David Yoho
I got an email from the owner with two pictures attached. The pictures weren't much help but the message said the top was finished with polyurethane but not the underside. I explained the importance of and reason for finishing all sides equally. I also offered a suggestion to dry the bottom side of the top and then apply several coats of poly to it. Hopefully this will resolve the issue.
