French Cleat - Design Parameters?
William Duffield
When making a French Cleat, for example to hang a tool cabinet or a clamp rack or a plane till on a wall, there are several structural parameters one takes into consideration to make sure it is not overloaded, causing fastener failure and catastrophic collapse. There are some obvious material and technique choices which we can discuss further, if we want, such as how best to fasten the fixed half of the cleat to the wall and the moveable half to the cabinet, but right now I have one question which has been nagging me for quite a while, leading to a case of paralysis by analysis.
When I take the board that will make the cleat to the table saw to rip it in two, the rule of thumb is to set the blade at 45°. Why? Is 45° really optimum? A higher angle (approaching 90°) would reduce the wedging action which puts tension on the fasteners.
Of course, I understand that in locations subject to earthquakes, a lower angle is better, because it may lessen the chance the S-wave will bounce the cabinet off the cleat, but there are other ways to mitigate that failure mode.
