Re: Bandsaw
TomD
I believe that in a survey FWW once published the band saw was the most dangerous tool in the shop (based on what showed up at ERs). It is after all the only one that you can slice your body fully in half on. It was suggested that part of the reason the BS was so dangerous was because people thought it was safe. I tend to think it was the tool, but maybe it was also the perception issue. You can feed yourself into a jointer like that famous scene in Fargo, you could certainly loose all your fingers there. Drill presses are very dangerous, they will kill you. I use a 25 dollar one I picked up, for light work, because it is just at the limit of what I can shut down if bad things start happening. If you ever get tied up in the heavy ones, you can't stop them and they will wind you up like getting caught up in the revolving door at the gates of hell. Drill presses are metal working machinery, and that stuff is evil, if you cross it. Google some pictures of metal working machines if you dare, you will find picture of heads attached to stuff that looks like someone made toffee.
I think table saws can be used with complete safety, if proper procedures are observed. The problem in commercial situations is that one can be sure that proper procedures are rarely observed, and that there are pressures to ensure that they are not observed. If one cut one's fingers off pre-Sawstop, it wasn't because safety devices and techniques to prevent it didn't exist, it was simply that they weren't implemented or observed.
