Why I like Lee Valley Spoke Shaves
I don’t often get tempted by offers into making impulse purchases but this was the case when Lee Valley introduced their spoke shave collection. Son-in-law and I made a coffee table over Thanksgiving and the legs are flared in two directions requiring a hand plane, as well as a straight and curved sole spoke shave to smooth the sawed profile. I was thankful to have bought these shaves.
Ergonomics: As usual LV designers put a great deal of thought into the shape. Think how much force it takes to drive a hand plane across 1 ¾” thick stock. One needs to replicate this force with a spoke shave that weighs but a small fraction of the hand plane, and with far less to grab onto. Compared to the angular Stanley spoke shave the comfy handles of the LV shave don’t make shaving trivial, but it is measurably better than the Stanley format.
Function: I found that the shaving thickness had to be optimally adjusted to get a smooth cut with no chatter or bogging down. The double screw arrangement made blade height adjustment precise. I don’t recall what the blades are made of but the edge held up well. The tight mouth was good to prevent tear-out but I did experience some jammed shavings. The curved sole fit our profile well and this shave sliced the partial end grain in the curve satisfactorily.
Sharpening was a pleasant surprise. The thick blades resulted in a wide bevel. The blade was trivial to hand hold for sharpening. The wide bevel sucked onto the flat sharpening surface which prevented rocking while rubbing the blade across the abrasive. As usual the backs of the blades were dead flat, a joy to encounter.
Re: Why I like Lee Valley Spoke Shaves
TomD
They are great. I have a full set, except that really long, one, and I need it, so maybe I should break down and get it. I have had mine a long time. Right now there are two camps in the spokeshave market, one the LV, and the other the LN. I hope they are friendly competitors since they have been friendly in the past. The design you so like has at least two roots. LV made the first Boggs shave I am aware of, one of the finest tools LV ever made. It did not have adjusters, but otherwise had the streamlined contours of the current LV offering. It was smaller, and I like them both small and large. Then the newer Boggs shaves and the LV techno shaves came out at about the same time. LV added some tech to their shave, but I am not sure it really improved anything. Though overall I haven't installed any spacers, or removed any adjuster screws, and I guess one could do the latter if one wanted to. Probably the no adjuster approach is better since certain aspects of the tool design flow from that, but that is what is great, you can do what you want with them.
My first woodworking project back in the 70s, at least the first serious one, was a paddle, so I have a fair "collection" of the beauties by now. I put it that way because I don't collect spokeshaves for the sake of it, but they were truly awful back then, a low point in production, so the upgrade path has been expensive over the years, but it certainly feels as though these will see me through.
Bruce, a MN Galoot
Did you get A-2 or O-1, Bill?
