how to stick tile to a plywood table top
In an intense holiday session son-in-law and I made a coffee table that will have a tile top and a wood rim. The requirements are as follows. The tile should be supported uniformly underneath with some adhesive that sticks it but supplies support in case something is dropped on the tile. A gap under a point of impact will crack a tile. Additionally, the tile needs to be just a bit higher than the wood rim so than when something is slid across the table it does not catch on the wood. So the viscosity of the adhesive must be such that its thickness after the tile is applied is predictable to get the tile height right. And the adhesive must be compatible with plywood.
Re: how to stick tile to a plywood table top
Did That
with Dark Emperador marble and walnut for my son.
1. Backer sheet (as in HPL) applied to the underside of the over-sized ply.
2. Tile glue applied thin with a fine-tooth trowel.
3. Tile laid on with 1/16" gaps using good straight edges to insure flatness in all directions.
4. When glue set (several days) the excess ply was trimmed off on the table saw.
5. Edge banding applied to leave the tile about 1/16 proud.
6. Tinted epoxy mixed to match the tile color and applied to the gaps like grout.
7. Excess resin carefully wiped off with DNA before set.
8. After epoxy set, blue tape applied to top of tile to prevent scratches.
9. Edge banding chamfered with router and then finish applied.
The piece, 2'x4' as a counter-height kitchen work table, is still in use after 12 years with all tile intact
?? re #6
Mark Nowicki
What brand epoxy and applied how?
TIA
Re: #6
System Three GP Resin with #1 Hardener, tinted with TransTint dye. Start by carefully applying paste wax on the top surface of the tiles as a protectant and release agent. Use a syringe to gently "inject" the mixed epoxy into the gaps. You can use a bit of thickener if you wish, but I didn't. This is a somewhat slow process as the resin will sink and fill any gaps under the tile joints; vibrating the piece can speed this up. When the resin stays level, wipe up any drips with a dry paper towel. When the epoxy begins to set up clean to top of the tiles and the gaps with a paper towel moistened with DNA. Do NOT use acetone to clean natural stone tiles because it will attack the factory glaze on the stone resulting in dull spots that will have to be repolished (very tedious).
Thank you, Mark.
PS
The alcohol clean-up MUST be done before the resin sets. Once too far along in the setting reaction, the alcohol will have no effect and the only way to remove the excess resin will be with acetone. The paste wax will make it easy to gently remove (razor blade) a missed drip that gets hard, but it will be difficult to get resin that sets up proud of the top surface in the gaps even with the tile without scratching the surrounding stone.
Of course, if using porcelain or ceramic tile, acetone for clean-up will have no effect on the tiles.
Re: PS
TomD
If you wait till green state of cure, and wipe with acetone, you can get a shine on the epoxy. Should you so wish.
