Any body got a Ceramic/glass top range?
My refrigerator died Thanksgiving day. It was cooling, but not enough to make ice. Took me until Friday to be sure. Checked out fridges at Lowe's and they had a Samsung normally $3299 marked down to $1899. I couldn't stand Over 3k but at 2K, I'm in.
They delivered the Fridge Saturday and while they were at it touched against the deck rail, denting the door with the ice dispenser in it. (A very gently touch and a slight crease. Offered me an additional $75 off or a replacement Fridge. They will be delivering the new new fridge with in a week. After they left we pealed the rest of the plastic off the doors and found another pair of dents on the drawer. These are all very slight, but that brushed stainless really shows dents int he right light.
While we were there we spied a Samsung range marked done from about $1800 to about $1000. Bought that too. Actually, they were out to them and had to drive to another Lowe's to get it and it will be here next Saturday. The reviews I read indicate the glass or ceramic top is prone to get scratches. How bad a problem is that?
Re: Any body got a Ceramic/glass top range?
Clint Searl
Clint Searl
I put a GE drop-in glass top in our kitchen about 15 tears ago. It may have acquired a bit of patina since, but any scratching is minimal and hardly visible.
paul in AZ
The potential to scratch is there but unless you slam pots around on it the reality is that this is a non-issue.
Dick Coers
Had a Whirpool glass top for two years now. We still like it, wife especially likes the cleanup. She likes electric, but hated keeping the pans under the burners clean. So far, so good.
terry
Have had the same one for 12 years now, no issues, would buy another in a heart beat
Re: glass top range - minor voice of dissent
Rum
We're on our second one at this house (the first made it about 10 years before some of the burners stated to go and it was much cheaper to replace with a better one than repair).
The first one was black topped glad which wasn't too bad, hid dirt reasonably well and you couldn't see scratches to speak of. For the replacement we got a white top, never again! It looks cruddy within minutes of using it and has several noticeable scratches after about two years of use. This should be qualified with some information on our pot selection which is heavily biased towards cast iron. If we only used stainless or enameled cast iron it would be significantly less of a problem IMHO since the bottoms of the cast iron pans tend to be a bit cruddier and this rougher.
My bigger complaint is the heat levels but that would only really be fixed by going with has or an induction top so not really the glass tops fault.
Hank Knight
We've had a glass top range for 7 or 8 years. If you make a commitment to keep the top clean, free of grease and polished, it will last for years. Ours has many, many tiny scratches from the cleaning and polishing, but they are "patina" and are virtually invisible. The range top is still shiny. The one noticeable scratch came from a tiny piece of grit that got between a pot and the range surface. My wife dragged the pot across the top and scratched it. We like the glass and would buy it again.
Gary Smyth
Actually I favor gas mostly because if the electric goes out for a length of time I can not only cook, but as backup I can turn on the burners to keep the house pipes from freezing too.
Still, I was overruled and the glass top has worked fine. Looks good and the electric also eliminates pots and pans exterior free of flame burn. The only problem I've had is that in a small kitchen the top serves as a place to set stuff.
Several months ago a plastic grocery bag touched the top and melted. That was a pain and care was exercised to remove the charred plastic without scratching the top. If I have to have electric, a glass top is my choice.
Gerry in North Surrey
Never again for me. I've had one now for 8 years and it's a real PITA to keep clean. No scratches, and I've been using everything on it including Comet. Mine's a white KitchenAid. Everything else works fine, it's just that keeping it clean is such a chore. I've switched to eating mostly salads because I don't want to spend the 15 minutes of shoulder busting scrubbing to get it clean after I use it.
Jesper, Denmark
Gas, gas, gas and gas again.....
Jesper, Denmark
With a gas range, you have complete and fast control of the heat. Great for all kinds of cooking and super easy to modulate. I'v had the glass top and other electrics - but gas is far the best.
We do not have gas installed in this village, which I handled with two 11 kg. (24 lb.) propane bottles installed in a small locker behind the house. One is connected and the other on stand-by. When a bottle runs out, you switch the hose to the other and buy a refill.
I use about two bottles per year, so cost is of no concern.
re: Keeping It Clean
Hank Knight
Keeping a glass top range clean requires a little commitment. Cooking usually leaves detritus scattered about. Frying in an open pan always leaves the stove top spattered with grease. Boil-overs and other spills that come into contact with the hot surface usually result in a cooked-on mess. These soils need to be cleaned up as soon as they happen - or at least not left over until "later." You should wash the glass top with soap and water just about every time you use it. We wash ours as part of the dish washing chore. A single-edge razor scraper makes short work of crusty messes and soap and water takes care of the rest. Every several weeks I squirt on a little polishing compound (available at your local grocery for glass top ranges) and polish the top for a minute or two with a damp sponge. This shines it right up and keeps it looking like new. All this sounds like a hassle, but it's easy; it just becomes part of your kitchen routine. If you don't mind dirty dishes accumulating in your sink for several meals, then a glass top range is probably not your best choice. But if you're a little OCD about keeping the place clean, then go for it. You'll like it.
Ours is black. Others have criticized the white ones as being hard to keep clean. I tend to agree. We've rented condos at the beach with white glass top ranges. They almost always look dirty and I found them hard to clean, especially the ones with a "wrinkled" or some kind of patterned finish. You can't see the grease on those surfaces very well; consequently, they're hard to keep clean. The shiny black ones clean easily and stay good looking for years.
Agree, but on the other hand . . .
Yonak
Jesper, my wife and I enthusiastically agree with you, but my mom had a ceramic cooktop and she was a great fan of it. Our rental houses also have glass cooktops and we haven't gotten any complaints.
Bedeviled by Comet ?
Yonak
Gerry, something tells me as soon as you started using agents such as Comet, that was the end for reasonably effortless cleaning. There are cleansers specifically designed for ceramic cooktops.
Re: Agree, but on the other hand . . .
Howard Acheson
Our ceramic cooktop is 12-13 years old and still in good shape. We had heard from others that white was to be avoided so we went for black. Using the correct cleaners and polish has kept it looking except for some minor scratches.
When it comes time to replace it, will will go with gas burners. For 30 or more years we used gas. It took some time to get used to an electric cook top. Next time will will go for a gas cooktop and electric separate ovens.
Must use grit free cleaners
Lee Schierer in McKean, PA
My wife insisted on one when we remodeled our kitchen 10 years ago. It still looks great, but she cleans it all the time. You can;'t use anything to clean it except the glass cook top cleaner or it will scratch. An cleaner with abrasives such as comet should not be used. Any spills, splatters or boil overs should be cleaned off as soon as possible and not allowed to bake on.
One thing not mentioned is that your pots and pans need to have flat bottoms to work well. We also found that aluminum fry pans tend to expand in the center due to the heat and become dished pretty fast.
No scratches here
John in NM
Seven years and counting. Even clean it with an ammonia/alcohol mix with no problems - last thread on glass tops I learned that one is not supposed to do this. Probably like all the fretting over ammonia and carbide - long on theory, short on experiment.
Anyway, my wife loves it. Easy to clean, no inserts to screw around with.
Bon Ami
"Hasn't Scratched Yet" :D
Think about induction cooktop.
Steve Schoene
We have hated the ceramic top range we had prior to redoing the kitchen. Cleaning wasn'the issue. Much more important is how slow it was to heat initially and how difficult to change temps. We don't have natural gas available and didn't want to install propane. But there is a solution--INDUCTION. Yes, you do have to have magnetic steel or iron pans--cast iron works well. But it is easy to adjust temps--the high temp is really high and boils water very quickly. Low temps will hold a simmer and even lower with melt chocolate or butter without scorching it. The price differential compared to good electric or gas ranges has gotten quite a bit lower than it was a few years ago.
Tony-Memphis
I think we had this discusssion recently. We have a glass top and I won't have another. Hard to keep clean ( and I mean streak free perfectly clean). The book says no ammonia or harsh cehmicals, no abraisives, etc. I use the cleaner meant for glass tops and it works well (but don't get any on the counter if you have formica - very hard to get off). Yes, we have several small scratches and we don't cook a lot. The book even specifies not to slide pots across it. Had to break our habit of removing a hot pan from the oven and setting it on the stove. On the positive side, when it is clean, it looks nice and it heats very quickly.
Honestly, I don't know what we'll try next. Hope it is not an issue for many years! Induction looks interesting.
Tony
