Re: alluminum door
John in NM
Like the other guys, I'd use a circ. saw with the right blade. I've done it with a router and it sucks. Horrible
With the circ saw, use good eye and ear protection. I like Dick's blade lube too, that sounds like a good idea. Since the one job I had where we used the router as a milling machine, I've always managed to avoid any aluminum I couldn't cut on my CSM. But then I can use a mill at work too, so I'm cheating
With a router, use a face shield over the eye protection, a ball cap or something to keep the hot chips out of your hair, a buttoned up shirt to keep them out of the back of your neck, and long sleeves with gloves duct taped at the wrist. Man am I glad I don't work anymore for the outfit that used to do this all the time!
If you do want to do it with the router anyway, cut it like a series of rabbets, increasing depth maybe 1/16 or less at a time. Assuming you use a clamped down base guide, this will keep your cuts more accurate. If you want a nicer finished surface, set the guide a bit shy of your mark to cut the bulk of it, then move the guide to the final mark and make a single full depth pass.
