Re: Stained oak floor
Randy Stukenberg
From what I have read, if the pot was iron (or steel), oxalic acid is what to use. OA reacts with the iron in the stain and changes or removes it. It is not supposed to bleach the rest of the wood much.
I just used OA on a cherry countertop that had black stains from water that was high in iron. It did reduce the stain, but not eliminate it completely. Not 100% sure I applied it strong enough. It lightened the rest of the wood slightly, but not much. A little stain took care of that. Try some on a scrap piece of oak if you have one, and neutralize it with a baking soda solution to make sure it doesn't discolor the wood. It turns cherry green as I unfortunately found out. A little more OA took care of that. I ended up washing with distilled water 2-3 times and stained it when dry. If you are using an oil based finish, it shouldn't be a problem. I have heard you can neutralize it with distilled vinegar, also.
