Ryobi drum sander belt problems
paul
I have a Ryobi drum sander 18/36 which i have had several years and the problem I have had is that it tears up the 3 inch by 96 belts on the right end that the tighting clamp is located on the drum .The clamp in itself is a miserable thing to navigate . It has torn up ryobi belts as well as ones from Industrial Abrasives of which I have used for years .The ends tear looser where they go through then drum into the clamp on the right end near the motor . For some reason both ends tar loose,mostly the right. Has anyone any Ideas????
Re: Ryobi drum sander belt problems
Lars Parrington
I used to have one of those (although maybe it was a 16/32). The drum clamps worked okay for me.
I once cut my strip of sandpaper too short, and was able to extend it with a tab of duct tape, so that on one side, the clamp was clamping only duct tape. Somewhat surprisingly, this worked okay. I did avoid trying to sand anything under the duct taped part.
I have heard of people covering the drum surface with adhesive velcro. Then you use velcro/cloth/loop backed sandpaper. It makes it easier to change grits.
Louis Lovas
I have that same drum sander, which I've had for 10-12 years. I completely agree the drum clamp to hold the end of of the sandpaper is poorly designed. I gave up using the clamp ages ago and just use double-stick tape (get the good kind - cloth-based, also known as carpet tape). for me that has worked fine.
As an aside, I only used the drum sander to uniformly smooth my own cut veneers and I've only used 80grit paper
