OT: Drilling a porcelain/cast iron bathtub
I don't usually post off topic, but this seemed like a likely question for our diverse group. I'm in the midst of a bathroom renovation and I've installed a new bathtub. I need to mount a bracket for a glass partition directly to the deck of the tub, which means drilling and tapping a hole in the tub. The tub wall is around 1/4" thick and has a shiny new white porcelain finish which I'd prefer not to ruin. The hole and surrounding area will be hidden by the bracket/channel, so I'm not too concerned about crazing or chipping becoming visible. Still, I may not be aware of any lurking snakes in the grass, and I'm not sure that my anticipated drilling method is the best. I'm planning to use a plain old jobbers drill bit, ground at a metal-drilling point angle. Would I be advised to use a diamond bit to cut through the porcelain before switching to the metal bit for the cast iron?
Any tips, tricks or caveats you'd like to share?
