A55 Smoothing Plane
Scroll saw problem
Scroll saw problem
Scroll saw problem
Jack Putnam
I am cutting out a pattern on a Excalibur scroll saw with 2 pieces of 1/2 inch plywood stacked together. When I have finished cutting out the pattern, I noticed it cut at an angle. I cut out the center piece and the top is narrower than the bottom. That is when I put the saw blade up against what I just cut and the saw blade is about 1/8 of an inch out from the top of the wood where the bottom piece is touching the saw blade. The table is level and the saw blade is new and is straight up and down. I noticed that there is burn marks on the inside of the pattern where I made the cut.
Could this result from stopping and starting again when cutting? Thanks for any help you can give me.. l
Re: Scroll saw problem
Jim DeLaney, Austintown, Ohio
The angling cut is from either not enough tension on the blade, or from operator error - you're putting side stress/tension on the workpiece as you're making the cut.
Us high tension on the blade, and let the saw do the work. Don't force it.
Also, since your workpiece is an inch thick, make sure you're using a blade that's designed/intended for work that thick.
del schisler
i don't have you brand of saw, i have the hagner 18v , the right blade and tention are what was wrong with the cut, try just 1/2 and check i bet it will be close to right on, if not try tention and cut again, i use only flying dutchman blades, from mike wolf, i don't get anything off on my blades , their are other's out their but this who i use the link if you don't want delete
https://www.mikesworkshop.com/blades.htm
Ron in Sterling CT
Jim & Del have given you good advice. Tension is your best friend. Increase the tension and let the saw do the work. Don't force it. Good luck.
Ron
Jack Brown
The biggest problem with any saw blade is, the blade is dull on one side or the blade isn't set the same on both side.
