Craftsman 391.5195 woodworking vise repair
ChuckInND
I thought that I'd share what I did with a woodworking vise to get it back up and running again after the quick release failed. https://sites.google.com/site/craftsman3915195viserepair/home
Re: Craftsman 391.5195 woodworking vise repair
What did you make the composite doughnut-shaped guide bushing from?
Are the ACME nuts somehow attched to your custom machined metal guide, or are they free to rotate, or are they attached to the vise body?
ChuckInND
The doughnut-shaped spacer was made from Trex, I may put a sleeve bushing in the center yet. The ACME nuts will get welded to the steel fabricated part between them. It took ALOT of head scratchin to figure out how I was going to do it all.
William Duffield
That's a useful technique. I've seen several other old, but otherwise still useful, vises fail by the same wear mechanism. I think you know to be very careful when welding the nuts. If you get them aligned incorrectly, the all-thread will be too tight, or even won't turn at all. In fact, adjusting the relative rotation can be used to adjust the backlash in the threads.
ChuckInND
Absolutely on the be very careful when welding the nuts. They will be welded while on the threaded rod to make sure that it works smoothly. Trust me, I have put ALOT of thought into this project. Thanks for the heads up anyway. It's easy to over look something.
