i belive the beiring guide could cause your blade to end up bad, if the beiring toutch's the teeth than blade is bad, i stick with the cool block's , mine delta is usa made and is 20 yrs or more , only had to change the tires , and adjust and that is all , with riser also,
I have not adjusted mine in a while so I may have forgotten, but I recall it being a pain in the butt. I don't want to mention them by name, but the name rimes with barter. They are rollers or ball bearings. It never occurred to me the adjustment would be to loosen the screw with an Allen wrench and let it flop about a bit and then re tighten it somewhere in the neighborhood. I really thought I would back off the screw, micro adjust a nob on the side and re tighten the set screw. Very expensive for what I got.
Wouldn't you only adjust two bearings when you change blades. The wheel doesn't change, so you only adjust the outside ones. I use a piece of paper as a feeler gauge when I adjust the Carter guides in my old Minimax. Not much of an issue for me.
