Tormek wheel replacements
JBD90
I acquired a Tormak 2000 with the rusted shaft burst wheel problem. I am considering buying a Grizzly 10 in wheel at half the price of the Tormak 250 Stone. I am planning on turning my own replacement shaft and pass on Tormak's $66 stainless steel shaft to fix the problem caused by their original steel shaft. Have any of you replaced your stone wheels with other than OEM wheels?
Re: Tormek wheel replacements
billv in SE Michigan
Guess depends on use. I tried a Jet 10" stone, but it feels a bit softer than the original. Typically use it for curved tools so having slightly dished out profile seems not to be a problem. I don't jump from flat to curved surfaces to sharpen much. The majority of my tasks are tune-ups versus a tool regrind.
Still keep the original worn smaller around for my jointer blades. Usually the abrasive grade change stone levels it out, compared with their diamond studded flatting tool. Have the same rust problem. filled the hole with a motor oil with the wheel flat on the bench, and it absorbed in the first inch of the hole and the rusting an mostly went away. The oil stays while the water evaporates.
JBD90
The oil trick is very interesting. I could clean up the shaft I have and treat the heck out it and still use it while creating an oil dam in the stone itself and the oil may leech onto the shaft and keep it water repellent. I respect cleaver, thanks.
Wonder if you couldn't also use a piece of magnesium or even aluminum, perhaps as a washer to provide some cathodic protection?
And how about coating the rusted shaft with epoxy to keep it dry?
The rusting of steel reinforcement is why concrete often fails in bridges.
Tony-Memphis
I had the same issue. Tormek was kind enough to sell me a stainless shaft at a dicsount -whoopee. I have not attempted to remove the original wheel. I'm hoping it will stay together until it is worn down enough to warrant replacing. Very frustrating.
Tony
