So I have not posted in awhile
Dustmaker Mike
I have been busy working on my garage and a a few other things getting ready to put my 68 Mustang coupe in it and start the restoration on it. I bought a heater for the garage to keep me warm while I work on it. The wood shop is all setup now to a point I can work in there in the summer with AC and the winter with heat. I have not been doing much if any wood working this year.
So for this winter and spring house project is what I call the refrigerator wall. Two pantries one on each side of the fridge and a cupboard to hole brooms and stuff.
Now my question is I plan on building most of the pantries my self the LOML wants white on the inside and a painted finish on the outside. I was thinking of using the MDF with the white lamanit on it already predrilled for shelving. Will it hold up or would I be better off using plywood and painting the inside a gloss white. We are going to use a combo of solid shelves and slide outs.
Between cars and house projects I might get a chance to sleep after work.
Later Mike
Re: So I have not posted in awhile
Don Orr
Good to hear from you Mike-welcome back!
I think the predrilled stuff would probably be OK if you don't move the shelf position alot. Might save you some time and energy too. No direct experience though.
Dustmaker Mike
I pretty much figure it would be set it and forget it, after we get it figured out.
Thanks Mike
