OT-Fireplace Insert
OT-Fireplace Insert
OT-Fireplace Insert
My son bought his first house in which was installed a "Napoleon" fireplace insert, supposedly a high-tech rig with "2-stage combustion" and low emissions.
Problems are, a) smokes up the house to get started and the b) when he closes the door, the fire GOES OUT!
Sumpin ain't right and I'm tempted to rip it out and set him up with a "normal" fireplace.
Anybody here have any experience with these things?
TIA
Re: OT-Fireplace Insert
Bill Turpin in WNC mountains
There are some very particular installation requirements that might be overlooked. Minimum stack height, minimum stack diameter, is there a direct access for combustion air. Get the model number, installation manuals are available for download. Good luck
john Veerkamp
High efficiency stoves require different starting and operating procedures than plain fireplaces. As Bill suggested, get the manuals and operating instructions before going off the deep end.
Dave
Dave
I've had a fireplace insert for 30 plus years, it takes about an hour of burning it hot to get the chiminey hot enough not to let smoke in the house. After that you can shut everything down and let the stove do it's job
Bill Howatt
I don't have one. According to friends who had high-efficiency stoves, burning it hot for a time doesn't just stop the smoking but is essential to keep the chimney from quickly crudding up.
Bill
John McGaw
So much unsaid. Does the insert have an air feed from outside? Has the chimney (and possible air infeed) been inspected for blockages? Are there any air/damper controls and are they being used appropriately? Some close inspection is probably called for.
I don't have one but I have acquaintances in Alaska and the Northwest who do and theirs invariably had sealed combustion with outside air on a separate control to adjust the level of the flame and it seemed to be possible to load the stove (the inserts are simply woodstoves without the skin), adjust the air and the fire would continue overnight. Some of them even had thermostatic control which would keep things operating on an even keel.
Thanks Guys
I'm having him call a chimney sweep and the insert company.
