Drill Press Woe-Part 2!
Tom
I took the quill assembly out of the drill press this AM. I forgot to mention that the model is a Delta 17-900.
There is a slot that runs the length of the quill that coincides with a bolt on the side of the housing. This is used for taking up slop? I redid this piece sometime ago, had to drill and re-tap, and made a new piece. One thing I noticed today is at the bolt/slot interface the bolt cannot be micro adjusted. See the link to the part(cannot figure out how to post pics) http://www.ereplacementparts.com/set-screw-p-83073.html
I was wondering if I ground the "point" to a cylinder this would allow more of a micro adjustment.
In a previous post ( Part 1) I mentioned that the bushing might need replaced but maybe this would do it?
Thoughts?
Re: Drill Press Woe-Part 2!
Lee Schierer in McKean, PA
Dog point set screws already come with a "ground down" tip. You probably want a full dog point, which will be longer.
Lee
Tom
BINGO!
I will check out McMaster Carr.
Thanks!!
ChuckInND
Do you have the Owners Manual ? If so, what does it say ? The drill press doesn't seem like it would be that old of a model to be worn out, unless you bought it from a fulltime production shop.
Tom
the owner's manual is a bit vague. The item that was suggested looks like it will do the trick.
ChuckInND
I think that I have the benchtop version of what you have. What I have is a Delta DP300L, Type 1, and I think that it was made in 2007. I took the tension off of the belt, then grabbed the chuck, and I felt a little play. That was the wrong place to grab it, grab it where the holes for the chuck are. The part that I grabbed tightens the chuck, and there is play there, but not if I grab the stationary part of the chuck, or spindle of the chuck, however a guy would describe it. The manual also says not to over tighten the belt, it just produces excessive wear in the pulleys, belt, and bearings. I'll have to go back and readjust it.
ChuckInND
Is the screw that your talking about have a nut to lock it in place ? That would be an adjustment for the quil, correct ? The spindle and bearings are inside of that.
Tom
Yep, that is the screw. I had re-drilled and tapped it years ago to 7/16"-20. But as I searched McMaster Carr that size is not available and the next size up the tip is too large in diameter to fit in the groove in the quill.
So I think I will clamp mine in a vise and start in with a file to make my own. Will report back!
Tom, I am not a machinist, (as I am about to demonstrate) but what I would do is cut off an Allen Wrench to get a short piece of straight hex shaft and epoxy that into the socket of the screw. Then I would chuck it in a drill and use that to spin it against a grinder. Then heat it a bit to get the shaft out of the socket.
Tom
I have been thinking about how to form the "cylinder" on the end od a bolt. Maybe some type of jig that will hold the bolt while I grind it. Barry your idea would work if I only needed the "cylinder" but it has to be on the end of a bolt.
Doug Wolf
Tom, I usually clamp the screw between some hardwood blocks in a vise and carefully file with a hand file. Just work your way around the screw a couple stokes at a time. You can make it round enough for your purpose.
What I meant was to grind the cylinder part on the tip similar to the picture posted earlier, not the entire set screw.
Depending on how much you need to reduce the diameter of the screw to get it to fit into the slot on the shaft, filing it as discussed will certainly work, but I was trying to allow you to spin the screw so you can "power" file or grind it.
Another thought is to use a bolt. Cut the head off the bolt and chuck it into a drill. Screw a nut onto it about half way the thickness of the nut. Screw the set screw into the nut, socket end first. You could grip the threads you intend to grind away to lock it into the nut. Then spin the exposed part again a file or grinder, The nut can be loosened with a wrench.
Just looking to get it done without a lot of hand filing.
Tom
Go it done! Took the bolt to the bench grinder and slowly made a cylinder. I re-assembled the drill press and the amount of slop is all but disappeared.
Thanks!
