Drill Press Woes
Drill Press Woes
Drill Press Woes
Tom
I have a Delta DP that is about 30 years old. It has some serious runout on the spindle. The only "adjustment" is a bolt on the side that you tighten up on the quill but this does not do the job. I have been struggling with this for years and I think I would like to get another unit.
So here is my idea and question. I could live with a bench model and I was thinking of a used industrial model. We have a large place that sells used equipment not far from where I live. But what would be the procedure for "checking" out the unit? How should I check for runout? I don't really want to just wiggle the quill.
Your help would be great!
Re: Drill Press Woes
Jerry Roberts
Tom, I think I have the same machine. Mines at least that old and is labeled Delta, Rockwell, NXRN3764 I think. The rod on mine doesn't work very well either but if I use pliers to tighten it works , well, ok. I did have to replace the, part that holds the bit. With my age I cant remember names anymore. .
ChuckInND
Could it just maybe need a new set of spindle bearings, or bushings ? I don't know which is in it.
Keith Newton
If you can get your hands on some 1/2" or less center less ground rod about 18" ~ 24" long to put in the chuck, this extra length will show how much the runout is, better than having a drill in there.
I had an old one of those once, that I think I helped some by giving the chuck a good smack with a deadblow mallet, while I had the long rod in it to indicate which way the runout is.
But, before that, you might take the chuck off, to see if you have any runout on the end of the tapper. The problem may all be in the chuck, which is easy to replace.
With the jaws open wide, there will be a screw with left-hand threads in the back of the jaws. Although you might ought to google to be sure of how to remove this one.
Lee Schierer in McKean, PA
It is a pretty easy project to replace the oillite bushings in the drill press. New ones are only a couple of dollars. There is also a thrust bearing that is easy to replace. I took mine out and then went to a bearing distributor and they helped identify the proper size replacements. Bearing replacement will be a lot less costly than buying a new drill press.
Lee
Tom
You guys have given me something to think about. I am going to take a long hard look at my unit tomorrow and see what's up.
Tom
Update!
I pulled the quill out this AM and it seems like the bushings that the quill travels in is where the "play" is located. To me it looks like I would need to replace these bushings in the cast iron head of the unit.
Advice??
Thanks!
ChuckInND
Tom, you don't give me much to go on, as in no model number, but you may want to look at this article. If it isn't the same model number, that site would probably also be a good place to ask on how to do it. http://www.owwm.org/viewtopic.php?f=1&t=110101&sid=8e0aa9d158cda781292ecd1664fe83a0
Tom
Sorry for leaving out the unit info. It is a Delta Model 17-900.
Cannot seem to figure out how to upload a pic.
