Mixing glue types?
Mixing glue types?
Mixing glue types?
Royce Meritt
Last night I was gluing up a small project using Titebond 3. (this project likely did not NEED Titebond 3 but I decided it wouldn't hurt.) About half way through the glue up I started to wonder if I was going to have enough glue. As it turned out, I did have enough. So, here is the question...
Had I ran out of Titebond 3 and finished my glue up with Titebond 2, would there have been any issues if the 2 types had co-mingled? Thanks.
Re: Mixing glue types?
Howard Acheson
Unless you can confirm that there will be no adverse affects, I am leery of mixing finishes or adhesives. Contact the Titebond tech folks and ask them. They are good folks to talk to.
good advice
These glues are complex formulations and only the manufacturer (and their competitors) knows the composition of what is in there. That said I doubt that anyone you will have access to calling Franklin will know enough emulsion polymerization chemistry, or even the details of the formulation, to predict the result of mixing so don't believe anything they say. Just don't do it.
I can not imagine any situation where there should be any inclination to mix glues. Use glue 1 until it runs out and then switch to glue 2. Any gluing operation can keep the two spatially separated.
Clint Searl
No problema
AZ in Colorado Springs
I don't have sufficient data to prove a negative, but at the hobbyist wood shop on base I've seen bottles with titebond III and I and/or II mixed together (this based on the color of the mixture within, and empty containers in the trash can). No one's ever reported a problem.
That said, I always take and use my own adhesives for my projects and for classes that I teach ...
