Go to DeWalt Servicenet
Grant in Iowa
Paul,
If I were in your shoes, I would first go to DeWalt Servicenet and study up on how the router comes apart and what the bearings cost.
If it looks straight forward, and the bearings are reasonably priced, then have a look inside your router to confirm what is damaged. Carefully inspect the armature, brushes, etc. and study how the brushes get re-installed. Sometimes brushes must be held back during assembly by a pin tool or similar. If you find that the brushes can be removed through access holes before removing the end cap, it should be straight forward. Keep track of how the brushes are oriented and which one went where as you remove them.
Have a look at the bearings you want to replace. Some of these newer universal motors are difficult to get the bearings removed without a special tool, if at all. The average bearing puller may not always work due to tight quarters. You might even go ahead and remove the bearings at this point, keeping track of which one goes on which end.
Once you have it apart and have proven to yourself that you can remove the bad bearing(s), THEN order the parts from DeWalt Servicenet. It should be a safe bet that you can get it back together with the new parts, and therefore worth the price of the bearings.
I have been down this road before and ordered the parts without taking the tool apart (a $65 angle grinder). Mistake! I couldn't get the bearing off one end due to how it was constructed. The bearing was pressed down in a depression. Even with a machinist background and neighbor with a machine shop we gave up. You simply couldn't get under the outer race shoulder to grab it. So the bearings went in my parts drawer and the tool to the scrap recycler. Looking back, I realize now I could have maybe welded something on the bearing to give me a way to pull it, but that might have done more damage to other components, since the commutator assembly was right there and riveted in place. Not all modern tools are meant to be repaired is the point.
Learning that has definitely changed my buying habits. Now I look carefully at the tool to see that it is made to come apart for service. I intend to keep tools for a lifetime, or until they fail. I buy tools with that in mind now.
Just trying to save you the same grief by sharing my experience.
Regards,
Grant in Iowa
