I have a cherry counter top that has black water stains around the edge of the sink. I have removed the sink and sanded down to bare wood, but a few black stains remain where water had leaked from the faucet. Is it oxalic acid that you use to bleach wood? Do I need to be careful to just apply it to the stains or can I just wash it over the area? Also, what strength?
The bleach to use to remove or reduce black mineral stains is oxalic acid. Many hardware stores and paint stores will have it. Follow the directions on the label.
Randy, I am not an expert on this, but I have struggled to find the answer to this question for years. (Actually, the question I was trying to answer was how to get pet stains out of oak flooring. but I think its a similar problem.)
As far as I can tell, there is no good answer. I have not found anyone who can give me the chemistry to remove the stain and leave the wood its natural color. It may be possible to use strong bleach to remove the stain, but then the wood will be white or very blond. And rough tot he touch form raising the grain. Not sure how deep you can bleach it or sand it to remove the rough surface without exposing the unbleached stain below.
The second problem is that if you then stain the area to match the rest of the counter top, after a while it will no longer match because the stained area may fade and the other continue to darken.
Your best bet might be to sand the entire top and then thoroughly seal the end grain around the sink opening and apply uniform finish to the top and live with the remnants of the stain.
Apply the bleach to the whole wooded area It may take a couple of applications to get the maximum effect from the bleach and you may not get it totally removed. Sand the whole panel evenly after it has fully dried. Give it a couple of days to fully dry.
Bleaching is chemistry. The goal is to bust some large colored molecule into smaller molecules. Smaller molecules are typically not colored. Hence, you need the right chemical(bleach) to decolor(react with) what ever the stain is.
Typically, Chlorox type bleach is especially effective for black caused by mold.
I suspect that oxalic acid is the wrong chemical for the job.
Oxalic acid forms a colorless compound when combined with iron. Iron forms a highly colored compound when combined with tannin. Oxalic acid will unbind the iron from the tannin to yield the colorless oxalic acid compond. And that's how it works. To be rid of mold stain you need to bust the what ever chemicals that make the black stuff into colorless pieces. This chemistry takes a strong oxidizing agent.
Randy, I'm sorry for the problem with your counter top. I don't have a suggestion for a fix. I'll leave that for the expert chemist.
..But I just want to make note here, next time someone asks about making a wooden countertop for a kitchen or bathroom, that there are hazards and inevitable ongoing maintenance, compared with stone or man made materials. When the question is asked, inevitably someone will chime in and say they've had a wooden bathroom countertop for 20 years and it looks like the day it was installed. My guess is these are lucky people who were very conscientious to get eveything sealed up good at installation and never had a surprise problem.
Personally I never saw the attraction of wood counter tops that were not cutting board areas, nor wooden floors in a kitchen either. But then others may not subject the kitchen to as much use as we do. That said, ours has not been subjected to butchering a deer yet and I am getting anxious about the lack of results.
I had some stains in my oak floor from my son leaving potted plants there without saucers and spilling water there when he watered them.
After sanding the floor some of the stains were still apparent and I poured peroxide on them. Seemed to help a bit. I am wondering if I had gotten some stronger peroxide and been more patience would it have done a better job?
After a little bit of research, I tried using oxalic acid. Our water has a high iron content, which reacting with the tannic acid in cherry leaves a black stain. Pretty sure it wasn't a mold issue. The oxalic acid wash worked well. Another application probably would have eliminated the stain entirely, but one coat was enough to be hidden with stain.
However, after two distilled water washes I used a baking soda wash to neutralize the acid, as directed. It turned the cherry green!
I'm going to try another acid wash and hope it reverses it. Wish me luck!
