Spice Box 4 -Drawer Dividers
PIC 1
Introduction: If you have the patience to read the details there are several tips one might find useful. What I describe may not be the easiest way to accurately fit dividers. If others have ideas let’s hear about them.
The picture shows the divider arrangement and appearance in a Spice Box previously made. From this picture you can get an idea of the goal for the dividers fitting.
The horizontal dividers are dadoed into the case sides as previously described. The vertical dividers are traditionally joined as show in the picture. The eye is focused on this joint so it must be crisp and tight. Unfortunately, I do not recall how I executed this joint 7 years ago when I made this box.
PIC 2
Step 1 was to cut the stopped dados for the vertical dividers. These dadoes must be accurately located or the resulting drawer openings will not be square. It is so easy to get something mis-oriented when doing these cuts. As an anti-screw up aid I marked with chalk about where the cuts were to be made so that I would not get a cut on the wrong side and that each cut would be referenced off the same edge of the divider. The dadoes were made on the router table like those in the case side, as previously described.
PIC4
The dividers must be notched on the front edge to accommodate the stopped dado in the case side. The divider was slid into position against the stop for the dado and a scribe mark made to locate the cut depth for the stop in the divider. Someone good with a hand saw would then saw out the stop, deftly splitting the scribe line. I almost tried it. Instead I cut out the stop on the table saw. I can set this vintage Delta fence to a few thousands of an inch accuracy but I was not confident I could set the fence accurately enough for these cuts. Any error would double when I flipped the divider for the opposite cut. I keep a collection of plastic pieces to be used as shims. A shim would effectively move the saw fence the thickness of the shim. I set the fence to cut just past the scribe line. Then I added a shim, chosen by trial and error starting thick and working to a thinner shim, to get the cut perfect on the scribe line so that there would be no gap where the divider meets the side. You can see the plastic shim in the picture.
PIC3
Traditionally the joint was made by dadoing a groove nearly to the front edge of the divider and then mitering the last bit. The mitered parts can be cut with a guide block and chisel. The guide block must be precisely positioned four times to make the two miters for the divider. In practice pieces I found it difficult to reliably get a perfect mating of the miter. Some were fine, while others had small errors resulting from imprecise positioning of the guide block in one of its four positions. Practice would have perfected this operation, but impatience drove me to find a more reliable way that involved less practice and less risk of a poor joint.
PIC5
This guide enabled the vertical divider to be precisely positioned for paring the miter with a chisel.
PIC 5A
Shown are the two scribe marks on the back of this guide that are in a line with the opening. I found it more precise to locate the guide with these lines than by the edges of the opening which had a slightly ragged edge.
The female miter in the horizontal divider ideally is just slightly less deep than the depth of the dado. To achieve this depth the width of this miter is just slightly less than the thickness of the divider (because the miter is 45 degrees). Hence, the spacing between the bottom tips of the ramps on the guide block must be a very few thousandths of an inch less than the thickness of the vertical divider.
PIC6
So how does one pull that off? The arrangement shown did the trick. The key here is the stop block on the end of the guide block. First, one of the 45 degree ramp cuts is made. I cut the second ramp to yield an opening what I hoped be slightly too small. I used the guide to chisel the miter (see below) and did a test fit. From the test fit I could estimate how much wider I needed the ramps to be apart. I moved the stop toward the blade by this estimated amount, slid the guide against this new stop position and shaved the opening wider by the amount the stop block was moved. After sneaking up on it with two tries it was perfect.
It is easy to coax the stop block by a tiny amount using the following technique. Make a tiny reference scratch, pencil mark or even note the relation of the stop block to some feature on the table top. While observing the distance between the stop black and this reference feature gently tap the stop block. It is easy to see the block move tiny amounts relative to the reference mark. I use some variation of this technique often.
PIC 7,8
The miter on the vertical divider is pared with the aid of the guide shown. I didn’t get the gap to hold the divider perfect enough and I had to add a piece of sand paper shim (400 grit was ideal) to get a snug fit. It was satisfying making these cuts with a sharp chisel. Two swipes and they were done.
PIC 9
This picture shows a test fit. Ideally the female miter in the horizontal divider is slightly smaller (more narrow) than the male miter on the vertical divider. In this situation the joint will be forced together when assembled. One definitely does not want to divider to bottom out on the dado in the vicinity of the miter or the miter will gap open.
PIC 10
This picture shows one box done. I was pleased with the joints. What remains is to round the fronts of the dividers. I may scrape them or use a router. Haven’t decided. I like the slight irregularities that scraping yields.
PIC 11
In the end I would recommend doing this joint different unless you are wedded to hand tool techniques. It is slow and tedious the way I described, but reliable. I think it would be easier to get good joints if the horizontal divider had the miter routed full width instead of a stopped dado and miter just on the end. Then the vertical divider could be fit with a donkey board and shooting plane by shaving the male miter as needed to get a tight fit.
