Damn Drift - Redoux
Damn Drift - Redoux
Damn Drift - Redoux
Brad
Good stuff, thanks all.
I bought a Timberwolf at Woodcraft yesterday but didn't install it until a few minutes ago.
TA-DA!!! Perfect tracking, much quieter machine and no where near the amount of vibration as before. This without setting the cool blocks and only positioning the blade on the center of the tires. The blade runs straight and appears as a thin line from the front. All this alone should have been clues.
Barry, last night I ordered the bearing set, Delta, made in USA, from Ebay for $49.99. I should have read your post first. I never thought of the bearings mashing dust on to the side of the blade and into the gullets. Oh well!
All you helpers whom were convinced the problem was the blade, reach back and give yourselves a pat.
The ideas shared by all are much appreciated. Those ideas have become more branches on my learning tree.
Good ol' WoodCentral
Re: Damn Drift - Redoux
del schisler
i use the cool block's on my delta, i myself wouldn't use the beiring's on my saw if by chance the blade went back to far , than the blade wouldn't be any good , so watch that, glad you got it going, i myself don't like the blades from http://www.supercutbandsaw.com/ they stay sharper than any that i have used,
You are welcome for the help.
I am not an expert by any means. I struggle with the Bandsaw. Perhaps my expectations are too high. On my table saw I have a Forrest WWII blade. (Don't want to start an argument about TS blades. Tried a bunch and the WWII works well for me, so I stopped looking. I'm sure there are other terrific blades out there, but I got to one that matched my expectations and stopped looking.) The point is, I can walk over to the TS and rip a board and it is often good enough to glue up right off the blade. I can slap the miter gauge on there and cross cut beautifully. the blade stays sharp for months or a year or more. The Bandsaw, not so much. Try to resaw, Install a fresh blade, and fiddle with it for forty five minutes. Don't dare use that blade for bowl blanks. Put the bowl blank blade back on and fiddle for thirty minutes. I even bought ten Identical blades. Some help, not much. Thought about a carbide blade. I have had one of the ten dollar blades last less than a minute. $10 not so bad. $150 would ruin my day.
OTOH, perhaps the Bandsaw is actually more versatile than the TS. Green wood, bark, straight, curves, you get the picture. I don't get much time in the shop and really don't want to spend it setting up the bandsaw AGAIN.
Back to the guides, I have dust collection on my saw. If it were more powerful, the lower guides might work better. I have considered setting up my air compressor to blow a blast of air across the blade when the saw is on, but I'm not quite that anal. I think what might be a good combination would be ceramic guides or cool block below the table and roller bearing above. Since you have bought the roller guides, try them on top and leave your cool blocks down under. I bought the Carter bearings and am consider re installing the Cool blocks at the bottom. I think the scraping action of the cool block or ceramic guides might solve the problem of the roller packing the wet saw dust onto the blade. If I hit the lottery, I might try the ceramic guides. About the only thing I have not tried.
On Wood Central BS stands for Bandsaw. Perhaps the other meaning of BS is more accurate for my opinion of my Bandsaw.
Brad
Barry,
I too use Forrest blades and use no other any longer. I make 1/4-sawn white oak to make tables and Forrest WWII makes clean, sharp edge cuts with no chipping. They must be kept clean for best results. I use Dawn and hot water. No need for expensive resin removers. I even cut veneer thin enough for bent walnut finger rings.
Del,
I'm not sure whether you are saying you like or do not like Supercut BS blades.
They are inexpensive and do not get very good reviews despite manufacturers claims they are premium and the best.
Brad
Glad you got it solved!
John in NM
I've used the Supercut blades too btw. They're a good blade for general use.
These days I make my own, either welded or soldered, that's cheaper of course but you have to do it! Supercut is a pretty good balance between price and convenience.
I've had to replace the bearings on my guides more than once - usually they are very common bearings so it doesn't cost much. The side bearings mine uses are 608's which is commonly used in skate board wheels and everywhere else. Half my tools have 608's in one end or the other :D I've found it's just easier to replace them than try to keep the dust out. If you ever have to do that, get sealed bearings rather than shielded - they last better in the dust.
Re: Glad you got it solved!
Brad
Maybe I'll send the bearings back and stick with the cool blocks.
Thanks for the info.
Brad
David Yoho
Barry, you have me believing your bandsaw really doesn't like you 8)
I use a couple of different width blades on my 14" Delta (no riser block) and all I do is release the tension, remove the blade, install another, adjust the tension, the thrust bearing, and the cool blocks, and get to cutting. I usually connect my wet/dry vac to control dust. Perhaps the main difference is I always cut dried wood. About the only wood I have cut that could cause a problem with dust build-up is pine but that's not very often.
My Delta tracks right no matter what blade I use and adjusting the cool blocks is a snap. That's why I kept it after getting my MM16. I realized I didn't want the hassle of adjusting those guides each time I changed the blade, so I keep the one-inch carbide blade on the MM16 for resawing and heavy stuff, and do all the curved work and general stuff on the Delta. Having two bandsaws is a luxury for sure.
Howard Acheson
Thanks for getting back to us about the solution to the problem. As I said in my prior response for the future, first look to the blade when trouble shooting blade drift. In my experience, blade sharpness and/or blade damage is the cause of drift in almost all cases. Have an extra new blade for the blade you most often use so you can confirm or reject that blade as the culprit.
Finally, I have used Cool Blocks ever since Mark Duginske first developed them. They are far superior to roller bearing IMO.
