How to soundproof a common wall of a semi-detached
Chuck in Mtl.
Just wondering the best method of soundproofing a common wall of a semi-detached housing unit. Would some of this sound deadening wall board work the best?
Chuck in Mtl.
Re: How to soundproof a common wall of a semi-deta
john Veerkamp
How big is the wall? The "best" way is to fir out, fill the cavity with sound deadening insulation and sheetrock. If the wall is very big the cost could be more than you want to spend.
A fairly complex topic. Are you trying to keep the sound in or out? What kind of sound? Music/voices or impact noise?
What wall is there now? Back to back drywall? Or is there a masonry wall there? What's in the wall? Plumbing and wiring?
Chuck in Mtl.
the common wall is offset 2 x 6. However the low frequency still comes thru. The idea now is to apply a layer of sound deadening wallboard. there is a product especially for this application at $70/sheet.
Chuck in Mtl.
or can sound deadening wall board be used applied over the wall board?
Mark Nowicki
How much space are you willing to loose on your side, I assume?
The best way would be a combination of another staggered stud wall, the cavity filled, drywall mounted on flexible metal channels.
Mark
Re: Z-channel
TomD
Look into Z-clips, they are a z shaped metal pieces that stand the drywall completely off the studs, and are said to be one of the more effective, while cheap, solutions.
http://www.youtube.com/watch?v=-IfYuNnRLgU
The 2 x 4's off set on a 2 x 6 base is supposed to be a good start on the problem. The idea is that the studs are independent of each other and to ones on one side are not affected by the vibrations (noise) of the other side. Unfortunately there is a lot to be lost in the installation. What should happen is the studs should be COMPLETELY isolated form the opposite set. It might be best for the studs to be side by side and about an inch apart, leaving the largest possible cavity between them. The cavity should be filled with a sound deadening batt. Sometimes the studs are spaced apart and the batt wound through them. This may defeat some of the purpose by compressing the batts around the studs and causing a path for vibrations to pass through.
Sometimes the electricians defeat the system by passing wires around or through the studs, again tying them together. Plumbers are guilty of this too.
Another flaw might be that electrical outlets are aligned directly across from each other allowing them to serve as a sound tunnel.
Any hole that passes directly or nearly directly through the wall can defeat it.
Assuming you don't want to tear the whole thing down and start all over, inspect it for obvious things like holes and outlets back to back. You might be able to seal the holes for wires in the outlets with Orange fire resistant foam like Great Stuff or similar caulk. Just be sure not to put in enough to touch the other side of the wall.
Might check behind the base board for voids and gaps and seal them.
Then the channels like those suggested by TomD are you next best bet. Use extension rings on the boxes. Homasote board is excellent. It might be expensive, but you can add it to the face of the wall and then cover over it with the Channels and new drywall.
Its all in the details.
Re: How to soundproof a common wall of a semi-deta *LINK*
mdclor
Just put on a pair of these whenever the sound is an issue.
Bose Headphones
waroland
Back before I retired, I was an engineer in TV Post Production and for sound proof walls we used offset 2 X 4 walls with insulation wound in between. We also installed two layers of different thickness drywall on both sides. One thing that helped with the low Hz is to isolate the wall floor plate from the floor. And that's the way we used to do it in the old days.
Ordinary wall insulation
It works for bathroom showers and kids rooms in my experience.
Chuck in Mtl.
Barry, all of this will be checked..Thanks!
Thanks to everyone...
Chuck in Mtl.
for your knowledge and suggestions!
Lee Gordon
Is there already drywall installed, or are the studs exposed?
If the wall is open, you can install insulation such as UltraTouch recycled denim insulation http://www.bondedlogic.com/construction-products/ultratouch-denim-insulation or Roxul Safe 'n Sound http://www.roxul.com/residential/create+a+quiet+home. These are two products that have good sound attenuation properties and are better choices than insulation that is primarily for prevention of heat transfer. If you're planning to weave the insulation around staggered studs, the denim stuff is probably the better choice.
If you want to go a step further, you can cover one stud wall with mass-loaded vinyl, which will further deaden sound transfer. You just have to remember to install it loosely rather than stretching it taut.
If you still want more, don't screw the drywall directly to the studs. Instead, mount resilient channel to the studs and screw the drywall to that. The system I like is to screw resilient clips such as Genie Clips to the studs and mount furring "hat" channel in them and screw the drywall to that.
The last step is the same, whether you have exposed studs or the drywall is already there. Laminate a second layer of drywall on top of the first using a product called Green Glue. And be sure to use 5/8" drywall, and not the lightweight kind. You want as much mass as possible in the walls. You may be familiar with a drywall product called QuietRock. Using Green Glue and a second sheet of drywall is essentially the equivalent of that but is easier to work with and a little bit cheaper.
The mass-loaded vinyl, Genie clips, and Green Glue can all be sourced from IsoStore http://isostore.com/products-by-use/walls/ as well as several other places on line. You can get hat channel at Home Depot.
Several companies make acoustical sealant. I like the one made by Green Glue.
