Damn Drift!!!
Damn Drift!!!
Damn Drift!!!
Brad Bransky
I have done absolutely everything including new tires to eliminate drift and cannot. The only thing I have not yet tried is a different blade.
Can the blade alone cause uncorrectable drift?
I've been at this for several days. No matter how many times I alter the fence, new blocks, readjust everything including coplaneing over and over, nothing works.
Help!
Brad
Re: Damn Drift!!!
Re: Damn Drift!!!
Virgil Johnson
I assume you are talking about your band saw. If the set is bad on the blade it will not cut straight or drift as you are calling it.
Re: Damn Drift!!!
Re: Damn Drift!!!
del schisler
first off you don't want the wheel's co-planer, you want the blade gulet to ride in the center of the top wheel , now set the guides and thrust beiring back , than do the cut down a board about 1/2 way the length of the table stop the cut and don't nove it and do the T bevel and set it to the cut , that transfer that setting to the fence, now if it drift's , do a new blade, but i bet it will not drift, chack back with a up date on this
Re: Damn Drift!!!
Re: Damn Drift!!!
del schisler
also watch the video with alex
http://www.youtube.com/watch?v=wGbZqWac0jU&list=FLYDEiGLzvqQNIl-nqvD2OOQ&feature=mh_lolz
Re: Damn Drift!!!
All It Takes
is 2 bad teeth, either dull or bent, to throw off a cut. Sounds like your problem. You can compensate somewhat with a variable fence, but I'd put on a new blade.
Re: Damn Drift!!!
ebd
Re: Damn Drift!!!
ebd
Wow. I'm planning (hoping) to thickness some Macasser Ebony for a small box for my good kitchen knives. I guess I better do a bunch of trial cuts with a less expensive wood. I never realized that the bandsaw was so particular. Glad this got posted. Maybe new blades are in the offing.
Re: Damn Drift!!!
Re: Damn Drift!!!
Brad
I've set the fence according to the drift numerous times and set everything else which can be set to no avail. I have to conclude it's the relatively new Timberwolf with which I resawed a freshly cut 6" red oak log. Probably not a good idea, huh?
Need to go to KC in a little while and will try a new blade later.
I'll update.
Brad
Re: Damn Drift!!!
Re: Damn Drift!!!
Brad
Or use your table saw.
Re: Damn Drift!!!
Re: Damn Drift!!!
Brad
You're we correct. Coplaneing on my Delta Doesn't work. If I try to coplane, the blade nearly comes off the front of the bottom whe
Re: Damn Drift!!!
Re: Damn Drift!!!
Jesse Cloud
Unless you are talking about a very special blade, I would normally put on a fresh blade before cutting an expensive wood like ebony.
I suspect its either the blade or you may be overlooking something that has loosened up and needs tightening.
Re: Damn Drift!!!
Re: Damn Drift!!!
Howard Acheson
Absolutely, in fact, a damaged or dull blade is the number one cause of blade drift. In my 50+ years of both hobbyist and commercial woodworking the first thing we did when a blade began to drift was to change the blade. While proper set up and alignment is important, there is nothing more important than the blade itself.
I suggest you either change the blade or buy a new one. I bet that replacing the blade will solve or greatly reduce the problem.
Re: Damn Drift!!!
Re: Damn Drift!!!
John in NM
That makes me think that the blade tension is pulling the wheels out of plane.
Re: Damn Drift!!!
I agree
Yonak
I agree with Howard. My first suspicion for drift would be the blade if a cursory look showed everything apparently properly in place.
Re: Damn Drift!!!
Re: I agree
I also agree. Have you ever had this saw set up well enough to limit the drift? If you have, what has changed to ruin the setup? The most likely thing is the blade. I have had blades that last less than a minute. Just touch a nail or embedded stone and it can be over for that blade. I would eliminate the possibility that its the blade by starting with a new one.
I have the Dugenski book. At least one of them, and its good. Get one if you don't have it. Contact Louis Ittura and get the catalog. Great data. I also saw a You Tube video form somebody (Carter Guides ????) that suggests the blade should track with the gullets on the center of the wheel and that you can adjust tracking by riding the blades forward or back.
I have a 14" Delta with riser block and have a Love/Hate relationship with it. Some days it mostly Hate. I find changing blades and adjusting for drift to be entirely too fiddly. Switching from resawing to bowl blanks and curve cutting takes way too long. I can get it tuned up and slice beautifully thin veneer and then it takes about thirty to forty five minutes to convert it back. Don't get me started on those stupid little roller bearings that are designed to press all the sawdust onto the sides of the blade. I have spent more money upgrading the saw than the saw cost new. I know the answer. Two bandsaws.
Re: Damn Drift!!!
Re: Damn Drift!!!
garthinsandiego
Another helpful video from Laguna: http://link.brightcove.com/services/player/bcpid914320544001?bckey=AQ~~,AAAAD7G5wBE~,5GVOQuNJN71MJ4fvSgdEsbYEKo4_iYO2&bctid=68238844001
Re: Damn Drift!!!
ebd
Re: Damn Drift!!!
ebd
Three reasons not to. One is the large kerf. Two is when trying to thickness (resaw) a board on a table saw, it is almost impossible to get an even thickness and clean cut. And three - the table saw blade isn't a large enough diameter to resaw a 6" board.
Re: Damn Drift!!!
Re: I agree
Brad
Good stuff, thanks all.
I bought a Timberwolf at Woodcraft yesterday but didn't install it until a few minutes ago.
TA-DA!!! Perfect tracking, much quieter machine and no where near the amount of vibration as before. This without setting the cool blocks and only positioning the blade on the center of the tires. The blade runs straight and appears as a thin line from the front. All this alone should have been clues.
Barry, last night I ordered the bearing set, Delta, made in USA, from Ebay for $49.99. I should have read your post first. I never thought of the bearings mashing dust on to the side of the blade and into the gullets. Oh well!
All you helpers whom were convinced the problem was the blade, reach back and give yourselves a pat.
The ideas shared by all are much appreciated. Those ideas have become more branches on my learning tree.
Good ol' WoodCentral!
Re: Damn Drift!!!
Re: not good reasons
Lars Parrington
too large kerf? -- use a 7-1/4" or 8" saw blade instead of 10" You can find nice ones for $20 with a 0.075" kerf. since the tablesaw makes a cleaner (and less wavy) cut, and therefor requires less cleanup, the 0.075" kerf ends up being just as effieicent as the kerf from a 0.035" bandsaw blade.
can't resaw a 6" board? -- put the blade at max height. this will get you ~2.5" with a small blade, or 3.5" with a 10" blade. saw through the board from one edge, and then flip it over and saw from the other edge.
warps or can't cut evenly? -- when doing the above, leave a narrow strip of uncut wood in the center of the board. cut through the strip later with the bandsaw.
Re: Damn Drift!!!
ebd
ebd
Have you ever done what you are suggesting - say with a board more than 12" long? Even with a short board it's a mess, it's difficult, has very poor results, wastes a lot of wood (cleaning up the resultant uneven sides) and absolutely not worth the trouble if you have a bandsaw and a re-saw blade.
I doubt you can make a single, full depth pass with even a small, supersharp tablesaw blade in something like macassar or any other hard, dense wood. I certainly doubt you could get a clean, single pass cut even in butternut. Even if you could, the need to cut from both sides would require that both edges were perfectly parallel. That's something that I don't thnk exists in the real world.
One more thing to think about. The danger of kickback with the blade burried inside the board is very real. This is simply not a good idea. IMO it's a very bad idea.
Re: Damn Drift!!!
Lars Parrington
ebd, i'm sorry that you've had a bad experience with this technique. without knowing all the deatils of what you've tried, i can't comment on what might have gone wrong. in any case, i didn't make this up. it is commonly used, and it provides good adequate results for lost of woodworkers.
i personally don't have a ton of experience with it. i have only used it a few times. i have done it with boards longer than 12", although only up to about 36". i don't see why longer boards would be a problem, but i can imagine it getty hairy if your board is too short.
i haven't tried it with any tropical woods. it's been a while, but i think i used it on cherry and on walnut.
i didn't say the result was perfect, or that the two cuts would perfectly coplanar. it does require a bit of planing to clean up after the cut, just like a bandsaw cut does (at least for a standard 14" saw with a steel blade). in my experience, the amount of extra wood removed for this cleanup is less than for bandsaw cleanup.
i'm no safety expert, so i won't comment on the likelyhood of kickback. i would avoid trying it with severely case hardened wood.
if you're still in doubt, take a look at some youtube videos showing how it is done. you'll at least see that it can work well, and maybe you'll be able to learn what you were doing wrong.
Re: Damn Drift!!!
ebd
ebd
There's no point in continuing - we simply disagree. I've done it that way and found the results less than superlative. I've also done it on an 8 foot long by 7 inch wide 5/4 black walnut board with a hand saw (rip teeth) with comparable results. In both cases the appropriate tool (a band saw) wasn't available. I won't be doing either of those things again. I've got a good band saw now, with a good fence.
