Spray gun clen up??
Spray gun clen up??
Spray gun clen up??
Tom
Will be spraying water base products soon and wonder what you guys use to clean up your guns? I was thinking lacquer thinner?
Re: Spray gun clen up??
Larry
I use water and then Lacquer thinner
don stephan
Haven't sprayed in a year, but I used to flush two full pots/cups of clean water through the gun after use, then disassemble and clean parts with cleaning brush kit. Seemed to eliminate need for lacquer thinner. After cleaning, can spray a bit of alcohol to remove water traces. I expect Jeff Jewitt's spray finishing book describes his recommendations.
Randy Stukenberg
I wouldn't recommend lacquer thinner. If you have any product left in the lines it will gel up and be a pain to remove. I shoot water-based lac almost exclusively. I run as much water through the gun as I can in the sink (hold the trigger open while letting water run in the feed tube) then spray a cup or so through the gun. Then about a half cup or so of denatured alcohol. Seems to do the trick.
Let's look at the theory
What you are spraying is a suspension of tiny balls of solvent swollen polymer suspended in water. Rinsing out the cup will be no different than rising out a glass of milk. Once the cup is clean a few bursts of water will flush the path through the gun. There can be some material collected on the tip. It should be taken off and rinsed clean. That is all the water is going to accomplish. Spraying another quart of water is not going to do any more.
If any material has partially dried or otherwise stuck to a surface it must be dissolved in a solvent that will dissolve the polymer to remove it. Lacquer solvent is probably as practical a solvent as any to do a final rise with, if necessary. Given that many different polymers are used to formulate these finishes one can not recommend any specific solvent so a general purpose solvent like lacquer thinner seems a good choice. Or ask the finish manufacturer for recommendation.
mdclor
I use Target products and the suggested cleaning procedure is soapy water followed by plain water. I then spray an ounce or two of DNA to remove any water that may be left. This practice works well for me and I haven't disassembled the gun in over 3 years.
