Best fix for confirmat screw pullout?
Tim Greif - West of Chicago
Youngest son bought a condo with a few items to fix, one being a couple cabinet doors where the cup hinge side mounts have pulled out the confirmat style Euro screws from the particle board carcass. What is the best way to repair this? Wood plugs and new wood screws?
Re: Best fix for confirmat screw pullout?
If
there's a panel on the other side (end or other unit) just use 1-3/8 course rock screws and it's done.
Re: If
I think Mark is right. That appears to be a screw with a finishing washer below the hinge, suggesting the cabinet is screwed to an adjacent cabinet. I would spackle the hole with Bondo or rock hard water putty just to support the hinge and screw and then screw right through it into the solid stuff next door.
Or get a big plug cutter (1/2" or bigger) and drill out the damage and glue in a plug, if there is no adjacent cabinet.
