drawer slides: Blum vs Lee Valley
Adrian
I was thinking of trying out undermount slides on a project. Blum is what I always hear about. But I noticed Lee Valley has a less expensive option that appears similar:
http://www.leevalley.com/US/hardware/page.aspx?cat=3,43614,43616&p=71024
Has anybody tried this? How does it compare to the Blum? Is it a problem if the drawers are longer than the slides with either of these?
Re: drawer slides: Blum vs Lee Valley
Keith Newton
I don't know anything about the other brand, but to answer your question, Is it a problem if the drawers are longer than the slides with either of these? Yes, the drawer has to be the designated length. There is a little barb on the back end of the slide, which needs a hole drilled for it to slip into when you install the drawer to capture the back, while the clip in front hold that end.
Adrian
Thanks for that information. It's helpful to know that I should just wait for the things to show up before making the drawers. One other major gotcha that I have discovered is that there is a secret minimum drawer width that Blum doesn't really note anywhere, and different locking devices that can make this smaller. Also confusing is the fact that Lee Valley sells "Movento" slides where are different from Tandem and not (apparently) distributed in the USA (except by Lee Valley, I guess). And I haven't managed to find the minimum width for these (and Lee Valley's customer service doesn't seem to know).
Do you know if I *really* need a 6mm and 2.5mm drill bit to install these? It looked like the 6mm might be important, but the 2.5mm just a pilot hole that would be fine .004" undersized at 3/32".
Adam of Oakland
Adam of Oakland
Hi Adrian - Thanks for the lead on the Lee valley slides! i'll definitely try those next time i need to.
I used the Blum undermount slides in a project this summer and turned out fine without a metric bit in my shop. I think for the 6mm i just used 1/4" bit. it's the hole placement that seems more important for the rear hooks. here's my jig that i used, noting that there's a left and right handedness for location on the back of my drawer:
Keith Newton
"Do you know if I *really* need a 6mm and 2.5mm drill bit to install these? It looked like the 6mm might be important, but the 2.5mm just a pilot hole that would be fine .004" undersized at 3/32"."
I believe the 6mm is screw size, which takes a 5mm drill, if you use the system screws to hang the runners in the cabinet. The nearest inch fraction to that is 3/16". But if you are hanging these in a plywood cabinet, you don't need to bother with using those type of screws, they are much better when screwing into mdf, or particle board.
As for the template for that barb in back, I have never bothered to make one for that. The first time you place the drawer on the slides, and shove it back, it will self mark, so I just center my drill on that mark.
It would be a good idea for you to wait until you have the slides, if this is your first time. There are certain things that are considerably different from just using the standard side mount, with a 1/2" space on each side.
Adrian
The 6mm is the size of the hole for the barb in the back of the drawer. It seems like mis-sizing that *might* be a problem. The 2.5mm appears to be for pilot holes for the locking device attachment to the drawer at the front. It's hard to see why precise holes would matter there. No way am I buying the $50 jig for drilling these holes! But having the right drill bits is another matter.
It was remarkably hard to confidently determine that the Movento slides minimum width is too wide for me. Blum doesn't seem to list this information anywhere. Lee Valley measured the sides to conclude that the absolute minimum inside drawer width is 160mm. So I have ordered the Tandem slides with the locking device that doesn't do side to side adjustment, which allows for a narrower drawer.
