M&T for a sliding garage door
cameron
I've just rebuilt the front of my garage/shop and am going to replace the rusted out old metal garage door with a more appropriate set of QS white oak sliding carriage doors (1870's Victorian.) I bought the 8/4 oak and have started milling it down but am wondering what is the appropriate tenon thickness for a 1.75" hanging door?
The doors will be: just under 8" tall, 49.75" wide and I plan on using three 3/4" solid flat panels.
My plan was to utilize 3/4 dadoes (for the panels/haunches) and traditional mortise/tenons. My Leigh FMT jig maxes out at a 1/2" thick tenon and I'm wondering if that is an appropriate thickness or if I would be better off using a different approach to aim for a thicker tenon (~9/16 would be about a 1/3 of the width, I'm worried that 3/4 might be too thick for a 1.75" door...)
Thanks
Re: M&T for a sliding garage door
May Depend
Which element, rails or stiles, will be weight-bearing?
Re: May Depend
cameron
I plan on using 2 hangers per door, one attached to each stile. The design I've drawn up uses a 10-12" bottom rail, three flat oak panels at the bottom (~5' long, ~10" wide), an 8" rail about ~2/3 up at the panel tops, 3 glass panes across the top and a 6" top rail.
Re: May Depend
These will be heavy doors. The stress on the M&T joint depends on how you configure the joints and the hinge method. Attached are just 4 of the options. In A and C the weight is carried by the to top and bottom elements putting the least stress on the tenons, whereas B and B2 put the carried weight on the vertical member putting more stress on the tenon. Either way, the stress on the corner joints can be relieved by using "L" form hinges (C and B2) that reinforce the corners. I would also consider a third hinge at your 2/3 crossmember.
Re: May Depend
cameron
Thanks for the reply although I need to clarify that these doors will be on barn-door type slides and thus hung vertically from wheeled brackets at the top corners. I expect that this means the stresses at the M&T joints should be minimal as compared to a typically hinged door...
Then
the weight-bearing elements are the vertical stiles. 1/2" rail tenons cut either cut "through" or 75% through the width of the stiles will do just fine in the "B" configuration.
PS
Do NOT forget to leave room for your panel inserts to expand and contract, right? ;)
You could go 3/4
I've made many 1 3/4" entry doors with 3/4" thick tenons. Never an issue. But on sliding doors, the additional tenon stiffness wouldn't be worth the effort, especially if you can make 1/2" mortises with existing equipment. That dimension would be even better if you stick the joints. You didn't mention any cope or stick operations.
Grant in Iowa
If you are hanging the door from typical sliding barn door hardware, then I would recommend using the construction detail Mark showed in his "B1" sketch. In this way, the load being carried through the door does not attempt to pull the tenons from the mortises.
It would also be wise to consider that glue will eventually fail, and at that point the tenons will slide slightly in their mortises under gravity pressure. Maybe pinned tenons will help prevent significant movement over time.
Sounds like a fun project. I have always wanted to build big heavy oaken doors.
Regards,
Grant in Iowa
